Cisco Systems have PIX with VPN, need to obtain isakmp key
Subject Author Date
have PIX with VPN, need to obtain isakmp key barretech 06-17-08
Posted by on June 17, 2008, 3:13 pm
Hello . We have a PIX 506e (6.3.5) and site to site VPN and if
possible we need to get the existing isakmp key from the PIX. The key
which was used to secure the VPN. We have physical access to the PIX
but when we run "show run" it only shows ******* as the isakmp VPN
key. How can we get this info? We purchased a second PIX for a backup
and we are going to put the existing config in place so we can have a
spare. Thanks in advance for any help
Posted by on June 17, 2008, 3:25 pm
I just checked and the PDM does not provide the unencrypted info.
Maybe if we use TFTP to copy the startup config to a server that will
do it?
> which was used to secure the VPN. We have physical access to the =A0PIX
> spare. =A0Thanks in advance for any help
Posted by on June 17, 2008, 4:10 pm
I found the answer in the "write net" command. Thanks anyway for
thinking to help and read.
> do it?
> > spare. =A0Thanks in advance for any help- Hide quoted text -
> - Show quoted text -
Posted by News Reader on June 17, 2008, 5:02 pm
>> do it?
>>> spare. Thanks in advance for any help- Hide quoted text -
You've not clearly stated whether you are referring to the RSA keys used
when "rsa-encr" is specified in ISAKMP policy, or whether you are
referring to a pre-shared key.
If you are referring to the RSA keys, I suspect the "private" key will
NOT be stored in the configuration, and the pre-existing keys may not be
exportable (you'd have to look into it).
I don't think copying the configuration to your new device will create
the swappable scenario you envision, unless you are referring to a
pre-shared key.
Hence, the need to be specific.
Best Regards,
News Reader
Posted by on June 18, 2008, 7:15 am
Thanks for your time. As I posted previously, we got it.
It appears that the last time this was successfully done to create a
backup PIX we had used the write net command, so we had the pre-shared
key and the pre-shared VPN key on a different TFTP server. I just
didn't have it handy here and didn't know how we got it out last
time.
To your point, I was writing of the line in the config that says
"isakmp key ********" . That is the pre-shared key.
I bet we don't use the RSA statement you mentioned since I see no
reference to it anywhere.
> >> do it?
> >>> which was used to secure the VPN. We have physical access to the =A0P=
IX
> pre-shared key.
> Best Regards,
> News Reader- Hide quoted text -
Similar ThreadsPosted
have PIX with VPN, need to obtain isakmp key June 17, 2008, 3:13 pm
re:LOCK OBTAIN TIMEOUT January 14, 2006, 10:15 pm
Obtain DNS Information from Provider April 26, 2006, 5:00 pm
PIX bugfixed software - How to obtain ? February 21, 2007, 5:16 am
sell two cisco 2600Xm that i used for obtain my CCNP January 7, 2007, 9:52 am
" i sell two cisco 2600XM that i used for obtain my CCNP January 7, 2007, 9:57 am
Obtain CCNA and CCNP certificaitons without exams(100% passing gaurantee) May 1, 2006, 3:27 pm
Obtain CCNA Certification In 72 hours....Without EXAMS.....100% Passing Gaurantee May 25, 2006, 5:17 pm
Obtain CCNA Certification In 72 hours....Without EXAMS.....100% Passing Gaurantee May 25, 2006, 5:18 pm
PIX ISAKMP: invalid udp len July 12, 2005, 9:28 pm
resetting just one isakmp October 31, 2005, 11:05 am
ISAKMP Profiles July 20, 2006, 5:09 pm
isakmp key lenght July 2, 2005, 2:49 pm
VPN client ISAKMP. July 8, 2005, 2:07 pm
ISAKMP nat-traversal ? November 28, 2005, 5:54 am
