Hello,
I've never been very good at navigating the maze of hardware / software options available with cisco routers.... was hoping someone could point me in the right direction.
I have a cisco 2620 router on the shelf that I'd like to play around with as a voice gateway. At the moment I simply want to connect a POTS line, set up a dial peer & test. Nothing fancy. I have a call manager in place that will send calls to the router over the LAN, so I don't need FXS cards for phones / etc.
The router is running "IOS (tm) C2600 Software (C2600-IS-M), Version
12.2(2)XT" w/ 16MB of flash.Based on what I've read, I think I need to order a VIC2-2FXO to connect the POTS line. Is that correct? If not, what should I order for this router. Also, are there any other hardware requirements? I'm confused as to whether I need to order a DSP card?
Any guidance appreciated!
Bill
