Our company recently purchased 4 frame relay circuits and 4 used cisco
1720 routers. The way the frame relay has been set up is 1 host and 3 remotes. I am curretnly working on the host and 1 remote at this time. I have been able to connect the 2 sites however I cannot figure out what to do to get the 2 lan networks to see each other.Router 1 (main site) ~~~~~~~~~~~~~~~~~~~~~~~~ interface FastEthernet0 description CBB Data Ethernet ip address 10.0.0.69 255.255.254.0 speed 100 full-duplex ! interface Serial0 bandwidth 1024 no ip address encapsulation frame-relay ! interface Serial0.16 point-to-point description 84th/Pinelake Frame Relay DLCI 16/16 bandwidth 1024 ip address 192.168.168.14 255.255.255.252 frame-relay interface-dlci 16 ! interface Serial0.17 point-to-point description 84th/Fletcher Frame Relay DLCI 16/17 bandwidth 1024 ip address 192.168.168.6 255.255.255.252 frame-relay interface-dlci 17 ! interface Serial0.18 point-to-point description 84th/Downtown Frame Relay DLCI 16/18 bandwidth 1024 ip address 192.168.168.10 255.255.255.252 frame-relay interface-dlci 18 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Router 2 (remote site) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ interface FastEthernet0 description 27th Street Data Ethernet ip address 10.0.10.69 255.255.255.0 speed 100 full-duplex ! interface Serial0 bandwidth 1024 ip address 192.168.168.5 255.255.255.252 encapsulation frame-relay frame-relay interface-dlci 16 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
int ser 0.17 on the main site is UP and UP and ser 0 on the remote site is UP and UP I can telnet to and from each site using the serial IP addresses.
what am I missing to allow LAN traffic to travel between the two sites?
I tried adding routes such as on the main site i added ip route 10.0.10.0 255.255.255.0 192.168.168.5
and on the remote site i added ip route 0.0.0.0 0.0.0.0 192.168.168.6
but it did not help. I am sure I am missing something simple here but I just do not know what. I figured after I get this remote working the others will be easy to follow.
Thank you KJ
