Hi All,
This is my first time configuring frame relay and I am having a hard time getting the pvc's to be active. I went tough various documents but they did not seem to help me. I would appreciate if you could guide me in the right direction.
Network diagram is as below:
+------------+ +------------+ +------------+ | R1 || R2 || R3 | +-------------+ Cab 1 +------------+ Cab 2 +------------+ S1 S0 S1 S0 10.0.0.1/8 20.0.0.1/8R1 is being configured as a normal FR DTE. R2 is being configured as a normal FR switch. R3 is being configured as a normal FR DTE.
On my side, I ensured that the interfaces are up. FR encapsulation is of the correct type. LMI exchanges are fine. Clock rate on R2 is setup to 64000. Not sure where I am going wrong...
Configurations are provided below:
---------------------------------------------------------------------------------------------------------------------------- ######## CONFIGS FOR R1 #######
2521_R1#show interfaces serial 1 Serial1 is up, line protocol is up Hardware is HD64570 Internet address is 10.0.0.1/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 301, LMI stat recvd 302, LMI upd recvd 0, DTE LMI up LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0 LMI DLCI 1023 LMI type is CISCO frame relay DTE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 14/0, interface broadcasts 0 Last input 00:00:01, output 00:00:01, output hang never Last clearing of "show interface" counters 00:50:11 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 316 packets input, 4954 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 318 packets output, 4429 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 2 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up 2521_R1# 2521_R1#show frame-relay pvcPVC Statistics for interface Serial1 (Frame Relay DTE)
Active Inactive Deleted Static Local 0 1 1 0 Switched 0 0 0 0 Unused 0 0 0 0
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = INACTIVE, INTERFACE = Serial1
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 out bcast pkts 0 out bcast bytes 0 pvc create time 00:50:50, last time pvc status changed 00:38:22
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial1
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 out bcast pkts 0 out bcast bytes 0 pvc create time 00:49:03, last time pvc status changed 00:48:55
2521_R1#---------------------------------------------------------------------------------------------------------------------------- ######## CONFIGS FOR R2 ####### R2_2503#show interface serial 0 Serial0 is up, line protocol is up Hardware is HD64570 Description: ****FRAME RELAY SWITCHING INTERFACE **** Internet address is 10.0.0.2/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 0, LMI stat recvd 0, LMI upd recvd 0 LMI enq recvd 1574, LMI stat sent 1574, LMI upd sent 0, DCE LMI up LMI DLCI 1023 LMI type is CISCO frame relay DCE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0 Last input 00:00:09, output 00:00:09, output hang never Last clearing of "show interface" counters 04:47:42 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1657 packets input, 23133 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 1654 packets output, 26279 bytes, 0 underruns 0 output errors, 0 collisions, 29 interface resets 0 output buffer failures, 0 output buffers swapped out 68 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up R2_2503# R2_2503#show interface serial 1 Serial1 is up, line protocol is up Hardware is HD64570 Internet address is 20.0.0.2/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 0, LMI stat recvd 0, LMI upd recvd 0 LMI enq recvd 181, LMI stat sent 181, LMI upd sent 0, DCE LMI up LMI DLCI 1023 LMI type is CISCO frame relay DCE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0 Last input 00:00:06, output 00:00:06, output hang never Last clearing of "show interface" counters 00:31:37 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 181 packets input, 2353 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 181 packets output, 2633 bytes, 0 underruns 0 output errors, 0 collisions, 3 interface resets 0 output buffer failures, 0 output buffers swapped out 8 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up R2_2503# Input Intf Input Dlci Output Intf Output Dlci Status Serial0 100 Serial1 101 inactive Serial1 200 Serial0 201 inactive R2_2503# R2_2503#show frame-relay pvc
PVC Statistics for interface Serial0 (Frame Relay DCE)
Active Inactive Deleted Static Local 0 0 0 0 Switched 0 1 0 0 Unused 0 0 0 0
DLCI = 100, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 out bcast pkts 0 out bcast bytes 0 switched pkts 0 Detailed packet drop counters: no out intf 0 out intf down 0 no out PVC 0 in PVC down 0 out PVC down 0 pkt too big 0 shaping Q full 0 pkt above DE 0 policing drop 0 pvc create time 00:35:34, last time pvc status changed 00:35:30
PVC Statistics for interface Serial1 (Frame Relay DCE)
DLCI = 200, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial1
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 out bcast pkts 0 out bcast bytes 0 switched pkts 0 Detailed packet drop counters: no out intf 0 out intf down 0 no out PVC 0 in PVC down 0 out PVC down 0 pkt too big 0 shaping Q full 0 pkt above DE 0 policing drop 0 pvc create time 00:31:38, last time pvc status changed 00:31:22 R2_2503#
---------------------------------------------------------------------------------------------------------------------------- ######## CONFIGS FOR R3 #######
2503_R3#show interfa serial 0 Serial0 is up, line protocol is up Hardware is HD64570 Internet address is 20.0.0.1/8 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 218, LMI stat recvd 213, LMI upd recvd 0, DTE LMI up LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0 LMI DLCI 1023 LMI type is CISCO frame relay DTE FR SVC disabled, LAPF state down Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0 Last input 00:00:01, output 00:00:01, output hang never Last clearing of "show interface" counters 03:47:26 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 216 packets input, 3136 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 217 packets output, 2821 bytes, 0 underruns 0 output errors, 0 collisions, 385 interface resets 0 output buffer failures, 0 output buffers swapped out 7 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up 2503_R3# 2503_R3#show frame-relay map Serial0 (up): ip 0.0.0.0 dlci 200(0xC8,0x3080) broadcast, CISCO, status defined, inactive Serial0 (up): ip 10.0.0.1 dlci 200(0xC8,0x3080), static, broadcast, CISCO, status defined, inactive 2503_R3# 2503_R3#show frame-relay pvcPVC Statistics for interface Serial0 (Frame Relay DTE)
Active Inactive Deleted Static Local 0 1 0 0 Switched 0 0 0 0 Unused 0 0 0 0
DLCI = 200, DLCI USAGE = LOCAL, PVC STATUS = INACTIVE, INTERFACE = Serial0
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 out bcast pkts 0 out bcast bytes 0 pvc create time 00:36:08, last time pvc status changed 00:25:29
2503_R3#----------------------------------------------------------------------------------------------------------------------------
Regards,
- PinkFloyd
