forward multicast between 2 interfaces on a cisco router
Threaded View
I want to forward multicast packets:
Src 192.168.2.12 multicast dst 225.2.1.14
And
Src 192.168.2.22 multicast dst 225.2.1.24
They are going to an address 10.100.1.8
So basically I want to forward from eth0 to eth1
I have played with pim and access lists but nothing seems to work.
Unicast and icmp all work fine just not multicast.
Any ideas?
Thanks in advance.
Router#
Router#
Router#write term
Building configuration...
Current configuration : 557 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Router
enable secret 5 redacted
enable password redacted
ip subnet-zero
ip multicast-routing
interface FastEthernet0/0
ip address 192.168.2.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.100.1.254 255.255.255.0
duplex auto
speed auto
ip classless
no ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password redacted
login
end
Router#
Re: forward multicast between 2 interfaces on a cisco router
 Does 10.100.1.8 know the multicast is coming, i.e. does it
send IGMP joins for 225.2.1.14  and 225.2.1.24?
 You do need to at least enable multicast on the interfaces
  ip pim sparse-dense mode
 That might just work.
 "show ip mroute" and "show ip mroute count" would be helpful.
 Or slightly more sophisticated:
  ip pim rp-address 1.1.1.1
  interface loopback0
   ip address 1.1.1.1 255.255.255.255
   ip pim sparse-dense-mode
REF:
Multicast Quick-Start Configuration Guide
www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094821.shtml
Rgds,
Martin
it does work if they are configured for the same subnet I do see the join going
to 224.0.0.22 for the 225 groups.
 So that's IGMPv3, in which case you also need to add "ip igmp version 3" to
F0/0 and F0/1.
Figured it out.
All that was needed was the igmp on the interfaces and ip multicast routing
The traffic I was trying to route had a ttl of 1 so once the traffic was fixed
it worked
ip multicast ttl-threshold?
I can recommend Cisco's IP Multicast Troubleshooting Guide.
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094b55.shtml
Nick B.
Site Timeline
