****************************************************** Attempting to load firmware using cisco to get firmware off of tftp server
****************************************************** west 1% cu -s 9600 -l /dev/ttyd2 Connected
------------------------------------------------- Catalyst 1900 Management Console Copyright (c) Cisco Systems, Inc. 1993-1997 All rights reserved.
Ethernet address: 00-C0-1D-81-75-C5
1 user(s) now active on Management Console.
Press any key to continue.
Catalyst 1900 - Main Menu
[C] Console Password [S] System [N] Network Management [P] Port Configuration [A] Port Addressing [D] Port Statistics Detail [M] Monitoring [V] Virtual LAN [R] Multicast Registration [F] Firmware [I] RS-232 Interface [U] Usage Summaries [H] Help
[X] Exit Management Console
Enter Selection: F
Catalyst 1900 - Firmware Configuration
-----------------System Information------------ FLASH: 1024K bytes V5.37 Upgrade status: No upgrade currently in progress.
--------------------Settings------------------ [S] Server: IP address of TFTP server 192.168.2.1 [F] Filename for firmware upgrades cat1900EN.9.00.07.bin [A] Accept upgrade transfer from other hosts Enabled
--------------------Actions------------------- [U] System XMODEM upgrade [D] Download test subsystem (XMODEM) [T] System TFTP upgrade [X] Exit to Main Menu
Enter Selection: T
This upgrade will overwrite the firmware version V5.37 in FLASH memory.
AT THE END OF THE UPGRADE, THE SWITCH MAY NOT RESPOND TO COMMANDS FOR AS LONG AS ONE MINUTE. THIS IS NORMAL BEHAVIOR AND DO NOT TURN SWITCH OFF DURING THAT TIME.
The TFTP protocol will be used to perform this firmware upgrade. This command requires the IP address of a TFTP server and the name of an upgrade file residing on that server. Use the following commands [S] Server: IP address of TFTP server, and [F] Filename for firmware upgrades to complete these requirements before starting the upgrade.
Do you wish to continue with the upgrade process, [Y]es or [N]o? Yes
TFTP transfer of cat1900EN.9.00.07.bin from server at 192.168.2.1 initiated...
********************Output from snoop command
***************** 192.168.2.5 -> west TFTP Read "cat1900EN.9.00.07.bin" (octet) west -> 192.168.2.5 TFTP Data block 1 (512 bytes) 192.168.2.5 -> west TFTP Error: not defined
********************Output from snoop command*****************
--------------------Settings------------------ [S] Server: IP address of TFTP server 192.168.2.1 [F] Filename for firmware upgrades cat1900EN.9.00.07.bi [A] Accept upgrade transfer from other hosts Enabled
******************************************************** Attempting to load firmware using SGI to put firmware on Cisco using tftp
******************************************************** west 9% ls -la total 3588 drwxrwxrwx 2 root sys 62 May 28 21:16 . drwxr-xr-x 34 root sys 4096 May 30 18:43 ..
-rw-rw-rw- 1 root sys 916480 May 28 21:12 cat1900EN.9.00.07.bin west 10% tftp tftp> connect 192.168.2.5 tftp> mode binary tftp> put cat1900EN.9.00.07.bin Error code 4: Illegal TFTP operation tftp> quit west 11%
***************** west -> 192.168.2.5 TFTP Write "cat1900EN.9.00.07.bin" (octet) 192.168.2.5 -> west TFTP Ack block 0 west -> 192.168.2.5 TFTP Data block 1 (512 bytes) 192.168.2.5 -> west TFTP Error: illegal TFTP operation
********************************************************************** Attempting to load firmware over xmodem using hypterterm connected to Cisco console port
********************************************************************** Catalyst 1900 - Main Menu
Enter Selection: F
Enter Selection: U
The XMODEM protocol will be used to perform this firmware upgrade. The user must initiate an XMODEM file transfer from the terminal side using an appropriate terminal application specific command.
Do you wish to continue with the upgrade process, [Y]es or [N]o? Yes Please initiate XMODEM transfer. Awaiting transfer...CCCCC XMODEM upgrade canceled: error(s) occurred during transfer.
Enter Selection:
******************End of Firmware attempts
According to documentation I found on Cisco's website all of these should have worked. I have followed the proceedure described on Cisco's website and I have tested the tftp functionality between the SGI system (TFTP server/TFTP client) and a Win2k system (TFTP server/TFTP client).
Any feedback would be greatly appreciated!
Thanks,
Rob Ramsey
