Firewall in a cisco Catalyst 3750
hello , i wanna block some ports in one of my vlans in a cisco switch , i have conected to the switch in vlan 3 , the adsl bridge- modem, a linksys router , and one server have access to that vlan by trunking port, i need to block some ports from the server in the adsl internet conection at that vlan, where i need tu put the acl rules , in the server trunking port interface of the swich , in the vlan interfaces , i try the two ways and de ports still opens
# i use this rules access-list 102 deny tcp any any eq 8080 log access-list 102 deny tcp any any eq 5432 log access-list 102 deny tcp any any eq 3306 log access-list 102 permit ip any any
# at the adsl modem interface interface FastEthernet1/0/6 switchport access vlan 3 ip access-group 102 in
#at server trunking Port interface FastEthernet1/0/15 switchport trunk encapsulation dot1q switchport mode trunk ip access-group 102 in
Thank you for your help Best Regards
gferragut
I'm not 100% but I think that Layer 3 access-lists don't work on layer 2 ports.
Bod43
Greetings,
The problem is that because of this line > switchport access vlan 3 on fa1/0/6, that port is only operating in Layer 2 mode (switchport) as a switched interface, therefore Layer 3 ACL's do not work. You need to apply a Layer 3 ACL to a ROUTED interface, so the solution is to change the interface definition into a Routed interface and the ACL should work there.
Cheers.................pk.
Peter
