Failover problem with Firewall Service Modul (FWSM) Catalyst 6500
Threaded View
I have set up two FWSM in Active/Standby Failover with Stateful Failover
and State Link in multiple context mode.
When I enable failover, the active unit sends the configuration in
running memory to the standby FWSM. Now my problem: all dhcp-server
commands beginning with dhcpd address ... and dhcpd enable ... are not
copied. If I force the standby unit to become active then DHCP-Server
and DHCP-Relay are not working!!! Anyway, DHCP-Relay commands have been
copied.
Even when I enter the dhcp commands again, the DHCP-Server and
DHCP-Relay still do not work.
Has anybody an idea how to solve the problem?
The switches run IOS 12.2.33-SXI3 and the FWSM version 4.0(11).
Many thanks
Andreas
and State Link in multiple context mode. The switches run IOS
12.2.33-SXI3 and the FWSM version 4.0(11). When I enable failover, the
active unit sends the configuration to the standby FWSM. Now my problem:
all dhcp-server commands beginning with dhcpd address ... and dhcpd
enable ... are not copied. If I force the standby unit to become active
then DHCP-Server and DHCP-Relay are not working!!! Anyway, DHCP-Relay
commands have been copied. Even when I enter the dhcp commands again,
the DHCP-Server and DHCP-Relay still do not work.
If I force the primary unit to become active then DHCP-Server and
DHCP-Relay are working again.
Many thanks
Andreas
Site Timeline
