Posted by dt1649651@yahoo.com on May 5, 2008, 12:06 am
The easy vpn documentation shows the command "crypto ctcp port" to
enable ipsec over tcp. I added this command on both sides server &
client but show crypto ctcp session shows nothing. And the log shows
the ipsec sessions are still working on 4500.
Besides adding the command crypto tctp on both sides and open the
firewalls to allow this port to get thru, what else do I need to do ?
Thanks,
DT
| Similar Threads | Posted |
| ezvpn with ipsec over tcp | May 5, 2008, 12:06 am |
| Is the crypto map order important ? Or is that between ezvpn and l2tp/ipsec ? | April 22, 2008, 3:28 pm |
| Using Cisco EZVpn together with router-to-router IPSEC config | August 21, 2006, 6:14 am |
| ezvpn: ip pool necessary? | June 27, 2006, 1:54 pm |
| Cisco 877 and EZVPN !?!?! | July 6, 2007, 10:45 am |
| EZVPN Problem on 877 to Cisco 300 Concentrator | July 11, 2007, 4:27 am |
| DHCP assigned address for ezVPN group | December 18, 2005, 12:18 pm |
| ezvpn with network extension mode question | December 4, 2008, 3:27 pm |
| EZVPN Server - clients connect but cannot pass traffic.. | August 31, 2005, 7:39 pm |
| ezvpn w/ router which has changing public address (PPPoE) | March 5, 2006, 4:18 am |
| Re: ezvpn fails on 1841 router with multiple dot1q intefaces | September 2, 2006, 11:40 am |
| ezvpn fails on 1841 router with multiple dot1q intefaces | August 29, 2006, 11:12 am |
| Failing Phase2 Auth - IPSec - All IPSec SA proposals found unacceptable | November 26, 2008, 7:37 pm |
| Problem with PIX EzVPN Site-to-Site | August 16, 2006, 11:11 am |
| IPsec within L2TP over IPsec - PIX. | July 23, 2006, 6:14 pm |
