Cisco Systems external vlan
Subject Author Date
external vlan mmark751969 03-19-07
Posted by on March 19, 2007, 6:02 pm
I have a number of catalyst 3750 stackable switches in the network.
We are on 5 floors, each floor has it's own catalyst stack which ties
into the core stack on the 1st floor. We are also layer 3 ip routing
capable and have a number of vlans defined. I have some requests to
run some dedicated ports, on other floors, that terminate to a switch
that's connected outside the firewall. I'm thinking the way i have to
do this is to define a vlan on an ip range that is defined on our
external static range. Then connect the ports in the other floors, to
access mode configured vlan ports at the floor switches and the core
switch. Then connect the core port to the external switch. If done
this way, i believe i'd have to route our external public address
range internally. Is there another way to do this. Thanks
Similar ThreadsPosted
external vlan March 19, 2007, 6:02 pm
PIX VPN using external addresses September 6, 2005, 8:33 pm
Howto hit an external ip with VPN September 27, 2005, 4:11 pm
PIX 515 Switch 8 External IPs October 24, 2005, 3:37 pm
Map external IP as internal IP? November 3, 2005, 11:08 am
PIX with two external Netowrks January 20, 2006, 9:22 am
PA-MC-T3 vs. External MUX on 7206VXR July 27, 2006, 9:37 am
On internal IP to many external IPs August 22, 2006, 6:03 am
two external ip addresses March 8, 2008, 12:42 pm
Multiple external IPs on SOHO97 November 10, 2005, 6:29 am
Allow all traffic from one external IP inside February 14, 2006, 2:42 pm
ACS not authenticating with external database March 3, 2006, 3:22 pm
Internal Web Server, External DNS November 16, 2006, 1:48 pm
connectivity via external modems December 27, 2006, 11:24 pm
Same external IP Address for two devices March 1, 2007, 12:32 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
