IS there someone who knows what is an "explorer storm"?
thanx
thanx
IBM token ring networks using Source Route Bridging use explorer frames to detect the network structure. If you try to connect to an other maschine, an explorer frame is send through the ring(s) in order to find the right bridge number sequence to reach the other side. All possible loop free sequences are detected and stored on your terminal. If you can't connectto due to an intermediate network failure, your terminal automatically choose an other way to reach the other end.
Unfortunly I you power on your terminal, the explorer cache is empty. Therefore every new connection causes a new explorer frame traversing all network rings reachable.
Due to a still unexplored human property, most workers come into the company at nearly the same time and turn on their working equipment. Due to another highly secret circumstance, most people really start to work, instead of drinking coffee for a random time. That's why a lot of explorer frames are send out in a very short period of time. Futhermore at each bridge the explorer frame is duplicated into the neighboring rings ... the storm cascade has started ...
Thank you, Lutz.
In the spring, I love standing in a storm cascade with no shoes on....
