Hi
Can I enter a /32 subnet mask on a ppp dialer0 interface. It is negotiated at the moment but I want it to be hard-coded.
When entering the command on the dialer0 inteface I get the error below:
router(config)#int dialer0 router(config-if)#ip address 111.222.111.222 255.255.255.255 Bad mask /32 for address 111.222.111.222 router(config-if)#
The router is an 837 with IOS v12.4.7
Is it possible to have a subnet mask for a ppp wan interface of either
0.0.0.0 or 255.255.255.255. It certainly negotiates it as I can see it in the routing table.thanks si
