Cisco Systems dialup POS to as5300 help needed
Subject Author Date
dialup POS to as5300 help needed FoxB 09-25-08
Posted by FoxB on September 25, 2008, 1:16 pm
Hello,
I have Ingenico 5100 terminals connection to AS5300 with mica modems.
When terminals are set for 2400 and I have
Code:
modemcap entry
POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=6
Terminals connect and information is exchanged.
But if I set the terminals to 1200
And
Code:
modemcap entry
POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=7
or
Code:
modemcap entry
POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=8
They got disconnected after first packet is exchanged.
Any idea what to change?
If additional information is needed I'll provide it( if it is not
confidential for sure).
Thank you in advance.
Posted by Aaron Leonard on September 26, 2008, 12:46 pm
Hi FoxB,
~ I have Ingenico 5100 terminals connection to AS5300 with mica modems.
~ When terminals are set for 2400 and I have
~ Code:
~ modemcap entry
~ POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=6
~ Terminals connect and information is exchanged.
OK.
~ But if I set the terminals to 1200
~ And
~ Code:
~ modemcap entry
~ POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=7
~ or
~ Code:
~ modemcap entry
~ POS_5100:MSC=&F&D2S0=0S15=0S21=0S22=0S23=0S24=0S29=4S30=2400S31=1200S64=8
~ They got disconnected after first packet is exchanged.
~ Any idea what to change?
I guess first of all, I would ask what different terminals you need to support,
and
how are they configured. Are some set for 2400 bps (V.22bis) and others for 1200
bps (Bell212a or V.22)?
Is it feasible to configure all terminals as desired? If so, then why not
configure
them all for V.22bis - which you say works fine - and be done with it?
Or must you support some terminals that are configured for V.22bis, and others
that
are configured for V.22/Bell212a?
In that case, you don't want to use S64 which sets a fixed modulation, and so
can't
possibly accommodate clients that are configured for different modulations.
We normally find configuring the MICA modems to automode for V.22bis (actually
V.23) and
below works well. Here is a typical configuration:
&f&d2s29=4ss53=0s15=0s22=0s23=0s24=0s0=0
If you should find that that a PoS call works well from one client but does not
from another
client, then here are the debugs that I would collect.
First, configure msec timestamps on your debugs, and "no logging console". You
might
want to log to a logging buffer. Also configure an ACL to match traffic to/from
your
application server. Also configure "service internal" (hidden global command).
Also
configure "modem call-record terse".
Also busy out all modems but one (if you can).
debug isdn q931 ! or debug cas
debug csm modem ! or debug modem csm, in some IOS
debug modem
debug modem mica tx s/p
debug modem mica rx s/p
debug ip tcp packet address <server-address>
debug ip packet detail dump <ACL> ! hidden command
Capture all of the debug output from a successful call. Then do the same for a
failed call.
Now compare and contrast the information from the two calls.
Have fun,
Aaron
Similar ThreadsPosted
dialup POS to as5300 help needed September 25, 2008, 1:16 pm
Here is a tutorial on Cisco dialup September 5, 2005, 6:49 am
Router as Dialup access server February 21, 2006, 9:15 pm
ISDN DialUP User is not connecting July 31, 2006, 6:39 am
ISDN Dialup to 2 x Seperate Routers October 6, 2006, 5:45 am
2503I and analog modem dialup February 4, 2008, 4:49 am
Cisco 837 to do a PPPoA dialup to ISP BUT bridge the static IP to a PIX 501 August 17, 2005, 3:27 am
Remote Dialup Access to network - Simple Solution? November 10, 2005, 7:21 pm
IOS image for AS5300 November 9, 2005, 10:11 am
Looking to buy a AS5300 Chassis November 22, 2005, 7:24 pm
AS5300 in POS environment March 1, 2007, 10:00 am
HOW TO DIAL UP FROM AS5300 TO PC-MODEM OVER PPP August 5, 2005, 4:15 am
WTS: AS5400/AS5350/AS5300 August 12, 2005, 4:51 pm
AS5300 > Control E1 Ports October 12, 2005, 8:18 pm
AS5300, Quad E1/PRI and unframed E1 ? December 1, 2005, 8:38 am
