I am sending non ip traffic through a 3750. The 3750 is in default configuration. Some of the frames are being dropped by the switch.
I assume some QoS is being performed. What are the default qos settings for the 3750 and how can I gaurentee that every non IP frame i send to the switch is forwarded (in the correct order).
I would also like to send this traffic over a VLAN as well.
The frames I am sending look like this.
DA, SA, 0xd800, payload, FCS.
The VLAN tagged frames would look like..
DA, SA, 0x8100, TAG, 0xd800, payload, FCS.
Thanks in advance.
