~ > I've got a bunch of modems out there connected to console ports on ~ > cisco routers. I know there is no way to reverse telnet to the console ~ > port like you can to the aux port. I need to figure out some way to ~ > send some modem AT commands to the modem. I tried doing a send con 0 ~ > then typing my command, but the banner that gets sent first is messing ~ > things up. In fact if you connect a modem directly to a pc and then ~ > copy and paste this in to a terminal session, you'll get nothing from ~ > the modem: ~ >
~ > *** ~ > *** ~ > *** Message from tty2 to all terminals: ~ > *** ~ > ats0? ~ >
~ > I've got a rs232 analyser online and see that it's getting to the ~ > modem, but no go. Even pasting ***ats0? into a terminal doesn't ~ > work. I need a way to blindly send data to the console port w/ no ~ > banners. I don't need to read back any data, just send. ~ >
~ > Surely others have run into this issue before. Appreciate any ~ > insights. ~ >
~ > Thanks in advance. ~ >
~ > SPH ~ ~ Doing some further research, it seems that if I can up the inter- ~ character delay to about 30msec all will be fine. Does anyone know if ~ this is possible to do?
A ha, you're the same guy whose post I answered in comp.dcom.modems a few minutes ago.
So piecing your story together, I have gathered that:
- you have USR Courier modems
- you have (some model of) Cisco routers
- the Couriers are cabled to the router console ports at some (unspecified) speed
So ... I will add some observations that may or may not be helpful here ...
a) If you have a Cisco 8xx router with the console/aux port, then we definitely have seen problems communicating w/ Courier above 57600 bps. (Although I'm not sure that we tried with 2 stopbits.) So, try 1 stopbit, try slower speeds.
b) It's somewhat tricky to configure a modem on a console port - see below for my deep wisdom on the subject that I try to impart to the Cisco TAC ...
Good luck,
Aaron
