Cisco Systems connecting 2*2600 with serial cable
Subject Author Date
connecting 2*2600 with serial cable Vincent FELLIN 08-10-05
Posted by Vincent FELLIN on August 10, 2005, 10:41 am
I try to connect two router 2600 with two serial cards and I just have DTE
cable .
Could you help me to connect thoses routers.
What are the connection necessar ?
I try a cross over connection and a back to back connection without succes.
I m not sure of the back to back connection . have you a drawing?
Thank you .
Vincent
Posted by Bob Goddard on August 10, 2005, 10:12 am
> DTE cable .
> succes. I m not sure of the back to back connection . have you a
> drawing?
You require 1 DTE and 1 DCE cable.
B
Posted by Vincent FELLIN on August 10, 2005, 11:38 am
Is not possible to make a adapter?
>> DTE cable .
>> drawing?
> B
Posted by Billl George on August 10, 2005, 1:25 pm
You can buy them for about $13.00 each. www.pccables.com or many other
places, I'm sure.
http://www.pccables.com/cgi-bin/orders6.cgi?action=Showitem&id=ID565536&partno=71005&search=CISCO&rsite=pccables.com&rcode=
>>> DTE cable .
>>> drawing?
>> B
Similar ThreadsPosted
connecting 2*2600 with serial cable August 10, 2005, 10:41 am
Serial cable for ip phones March 19, 2006, 8:30 pm
connecting async/sync serial to external CSU/DSU June 26, 2006, 10:56 am
Cisco 837 and a serial modem? Special cable required? July 24, 2005, 7:02 pm
Connecting 3 switches to a fourth switch, each with its own crossover cable shuts down ports March 29, 2007, 2:04 pm
Connecting to Pix vpn from behind pix January 10, 2006, 2:55 pm
Connecting via vpn August 9, 2007, 4:00 pm
Connecting to PIX using Linux October 18, 2005, 6:51 am
Having Problems connecting through VPN March 28, 2006, 4:26 pm
VPN Client not connecting.... August 13, 2007, 9:08 pm
Connecting to a PC Anywhere host via VPN from inside a Pix November 4, 2005, 4:28 pm
Connecting two Cisco PIX 515 as per following Picture February 28, 2006, 10:40 pm
Connecting two networks with ISDN March 18, 2006, 11:01 am
PIX 506E Connecting two different Companies March 22, 2006, 12:27 pm
VPN client 4.0.4: connecting from static IP April 3, 2006, 4:49 pm
