Configuration register setting question
I have an older 4000 switch with the following output from a "sh boot" command. I'm trying to determine what the configuration register setting (0x2) below will yield during a boot. Are configuration register settings uniform across all platforms ?
*** sw-cgd-4th> (enable) sh boot BOOT variable = bootflash:cat4000-k9.7-1-2.bin,1; CONFIG_FILE variable = bootflash:switch.cfg
Configuration register is 0x2 ignore-config: disabled auto-config: non-recurring console baud: 9600 boot: image specified by the boot system commands
keithdew
Check out this link from Cisco. It explains the config register values for the 4000 series.
About the second part of your question, the answer is yes and no. The same config register means the same thing across all platforms, but not all config register values are supported across all platforms. HTH.
Robert
Robert
Thanks for the URL. One more question, my above example indicates "0x2"
Is this setting the same as 0x2000 or 0x0002 ? The document indicates a
16bit register and I'm unsure if there is any truncation of zeros ?
keithdew
I believe that would be the same as 0x2000.
Robert
