Cisco 2924 XL-EN 12.0(5) WC9
I have the following definitions in running-config:
line vty 0 4 password ubdpnpdf login terminal-type VT300 exec-character-bits 8 length 0 international line vty 5 15 password ubdpnpdf login terminal-type VT300 exec-character-bits 8 length 0 international
This is what I want : (and put in my startup-config:
! line vty 0 15 password ubdpnpdf login terminal-type VT300 exec-character-bits 8 length 0 international !
AKA: I want to combine this in a single line vty 0 15 block.
I tried copy startup-config running-config, and it left the vty definitions in 2 blocks.
I tried to "configure" and again, it left it in 2 blocks.
I assume that the existing definitions are not deletable from a running system and so trying to create a "0 15" block results in no action since it would duplicate the existing 2 blocks ?
Is a reboot the only way to get this done ? Or is there some magic command incantation that would solve this ?
(those 2 blocks were probably created when I was toying with the switch during initial "get to know it").
