I've been trying to get access to the CLI on a AIR-WLC2006-K9 WLC I bought a few weeks ago as part of a lab kit, but have been very unsuccessful.
I've tried a straight-through serial cable, a null modem serial cable, and two DB-9 to RJ45 serial cables (the type used with most Cisco equipment) with an RJ45 coupler between them, but none of them seem to work (no output on my terminal emulator).
I've checked my terminal emulator (minicom) settings multiple times (9600 baud, 8 data bits, 1 stop bit, no parity and no flow control), and I'm sure they are correct anyway since these settings are the same for all other Cisco routers, and it works fine on my 1841 and other routers. I'm just having issues with this WLC. :(
Is there a special type of cable I need to use for this WLC?
Any clarification truly appreciated!
Regards
Hamzah
