Cisco Systems cisco vpnclient for cmd script
Subject Author Date
cisco vpnclient for cmd script joe 04-30-08
Posted by joe on April 30, 2008, 11:25 am
hello I have a couple of scripts to automatically connect with the
cisco vpnclient one is a vbs script, the other is a cmd script. The
vbs scripts enters 'y' after the vpn client prompts for y/n to
connect. Is there a way to disable the prompt y n? I am trying to run
connect to the vpn server without using the vbs script. Thanks
Posted by Martin Bilgrav on May 1, 2008, 1:19 pm
I would say so - The VPN dialer has its own CLI commands alltogether.
Check the VPN admin user guide on CCO
Posted by Martin Bilgrav on May 1, 2008, 1:20 pm
http://www.cisco.com/en/US/docs/security/vpn_client/cisco_vpn_client/vpn_client46/administration/guide/vcAch5.html
Similar ThreadsPosted
cisco vpnclient for cmd script April 30, 2008, 11:25 am
configure idle timout for Cisco vpnclient for linux 4.6.0 June 22, 2005, 12:42 pm
VBS script to backup Cisco configs December 1, 2005, 7:44 am
Batch Cisco Configuration Script June 26, 2007, 12:29 pm
VPNclient and access to LAN. September 9, 2005, 1:59 pm
VPNclient and PIX515. January 11, 2007, 7:01 am
Cisco + Linux How to store configs in one script? August 8, 2006, 4:34 am
[LONG] VPNClient - NAT - LAN to LAN tunnel September 19, 2005, 3:48 pm
assigning vpnclient static ip July 11, 2007, 2:59 pm
Working even if missing some commands - VPNclient June 1, 2006, 11:31 am
udp traffic not passing over vpnclient connection to pix ASA 7.2 August 29, 2006, 4:24 pm
Host tracking on Cisco switch/routers using perl script February 7, 2007, 5:15 pm
Cisco 1700 Config not able to processing internal webmail script October 21, 2007, 8:31 pm
Cisco CSS load balance weighted round-robin perl script February 13, 2007, 9:30 pm
enabling/dissabling ip multicast traffic in real time on a Cisco router using windows script July 23, 2005, 9:10 pm
