Cisco VPN3030 Lan to lan NAT
Setup:
ClientA -- NetA -- VPN3030 ....@.... FW-1NG -- NetB -- Server
Desc:
ClientA on NetA (10.0.0.0/8) needs access NetB Server (Host=172.16.0.1)
Via Lan to Lan tunnel set up between Cisco VPN3030 and a Checkpoint FW-1 NG.
Problem:
NetB Server (Host=172.16.0.1) subnet is also routed elsewhere on NetA.
Also NetA subnet is routed locally on NetB
I need "one-sided" NAT
Here is what I have done:
- Reserved an IP from local pool in VPN3030 IP=192.168.100.100
- Create L2L with Peer for FW-1, PSK, Local network=192.168.100.100 /32
Remote=172.16.0.1/32
- Create L2L-NAT rule and enabled it:
Source=10.0.0.0/8:Trans=192.168.100.100/32 Remote=172.16.0.1/32
- Add Static route towards public interface for 192.168.100.100/32
This does not work. My guess is that the NAT rule is wrong, or that the
terms source:trans - Remote means different
that I imagine.
Is it true that the above NAT rule means that 10 gets its source translated
into 192.168 ?
And how must I interpritate the Remote ?
What I want to do, is to have ClientA on NetA (10.0.0.0/8) access the
IP=192.168.100.100/32 and have this translated
into 172.16.0.1/32, and then put this into the tunnel towards FW1-NG
How can this be done in the VPN3030 ??
Please comment ...
Regards
Martin Bilgrav
Site Timeline
