Hi Guys,
I am configuring our Cisco 3750 to support CIsco CME, i have noticed that we can configure the interface either as ab access port or as a trunk and both will support Voice and Data Vlans.
EXAMPLE 1 ACCESS PORT
********************************interface GigabitEthernet0/11 switchport access vlan 141 switchport mode access switchport voice vlan 41 srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 queue-set 2 mls qos trust device cisco-phone mls qos trust cos macro description cisco-phone auto qos voip cisco-phone spanning-tree portfast spanning-tree bpduguard enable
EXAMPLE 2 TRUNK PORT
**********************************interface GigabitEthernet0/1 switchport trunk encapsulation dot1q switchport trunk native vlan 141 switchport trunk allowed vlan 41,141 switchport mode trunk switchport voice vlan 41 srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 queue-set 2 mls qos trust device cisco-phone mls qos trust cos auto qos voip cisco-phone spanning-tree portfast spanning-tree bpduguard enable
Kindly ignore the Qos configuration as Auto Qos has been used in both configuration; cisco's macro configuration applies the access port configuration while cisco's documentation recommmend the .1q trunk configuration.
I have tested both in the Lab and both have worked just fine; i always thought that we have to use .1q for security reasons.
Your recommendation as the best practices is higly appreciated.
Regards, Andy
