I have a 515E at home, its got a DSL router on its outside interface, my desktop machine on its inside interface and a webserver on the DMZ. (security levels 0, 100, 50 respectively)
Its all working fine, I went through the ASDM and enabled all the security features I could, but i am wondering if it has more security options that could be configured (Im interested in IDS/IPS and DoS specifically). Do I need to enable this stuff manually? is it turned on by default? are there software upgrades with more features?
The Reason I ask is because up until now I have been running a personal firewal on the desktop as well, I would Like to get rid of it but I want to be sure I am safe first.
Sh ver Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Disabled Maximum Physical Interfaces: 3 Maximum Interfaces: 5 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited
Also unrelated, is there a "show log" command like on IOS for the PIX? I can't see any logs anywhere, do I have to use syslog for that?
Flamer.
