Cisco Systems cisco pix 515 port forwarding - NOT possible? hard to believe..
Subject Author Date
cisco pix 515 port forwarding - NOT possible? hard to believe.. google 07-27-05
Posted by on July 27, 2005, 12:23 am
i don't understand why this can not be done.
i have a cisco pix 515 with a pool of static IP addresss (14IPs)
assigned by ISP. My internal network is 10.10.0.0/24. the pix has 2
interfaces. web and ssh traffic from outside to internal web/ssh server
is fine. internal client have no problems accessing the internet.
i have nagios clients NRPE installed on the internal network and nagios
monitor server installed outside of the pix firewall. i would like to
allow the nagios server to monitor the server behind the firewall.
to save IPs, i am using 1 static IP address for mapping and use it to
port forward to all internal IP addresses at 5666. for testing, i
telnet from outside the firewall to x.x.x.146 x.x.x.147 port 5666 5667
5668 5669 all fails except to port 5666 on x.x.x.147.
here is my current config. any help would be greatly appreciated!
g.
mypix# show run
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xQIfy7TWQw.w encrypted
passwd T7Jj6BURLPDx encrypted
hostname mypix
domain-name cisco.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit tcp any host x.x.112.147 eq www
access-list 100 permit tcp any host x.x.112.147 eq ssh
access-list 100 permit tcp any host x.x.112.147 eq 5666
access-list 100 permit tcp any host x.x.112.147 eq 5667
access-list 100 permit tcp any host x.x.112.147 eq 5668
access-list 100 permit tcp any host x.x.112.147 eq 5669
access-list 100 permit tcp any host x.x.112.146 eq 5666
access-list 100 permit tcp any host x.x.112.146 eq 5667
access-list 100 permit tcp any host x.x.112.146 eq 5668
access-list 100 permit tcp any host x.x.112.146 eq 5669
access-list split permit ip 10.10.0.0 255.255.255.0 10.1.2.0
255.255.255.0
access-list nonat permit ip 10.10.0.0 255.255.255.0 10.1.2.0
255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside x.x.112.146 255.255.255.240
ip address inside 10.10.0.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool poolclient 10.1.2.1-10.1.2.254
pdm location 10.10.0.0 255.255.255.0 inside
pdm history enable
arp timeout 14400
global (outside) 1 x.x.112.150-x.x.112.157
global (outside) 1 interface
global (outside) 1 x.x.112.158
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.112.147 10.10.0.101 netmask 255.255.255.255
0 0
static (inside,outside) tcp interface 5666 10.10.0.103 5666 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 5667 10.10.0.104 5666 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 5668 10.10.0.105 5666 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 5669 10.10.0.106 5666 netmask
255.255.255.255 0 0
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.145 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 10.10.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap client authentication LOCAL
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool poolclient
vpngroup vpn3000 dns-server x.x.x.1
vpngroup vpn3000 split-tunnel split
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
telnet x.x.x.253 255.255.255.255 outside
telnet 10.10.0.0 255.255.255.0 inside
telnet timeout 5
ssh x.x.115.0 255.255.255.0 outside
ssh 0.0.0.0 0.0.0.0 outside
ssh 10.10.0.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
username x01 password zyjVE5 encrypted privilege 2
username x03 password Vct8HaSB encrypted privilege 2
username x2 password hXVsT encrypted privilege 2
username x5 password . szmqxT encrypted privilege 2
username x4 password tUTLfiAnl encrypted privilege 2
username x7 password fJst049 encrypted privilege 2
username x8 password SqKcA/Nc encrypted privilege 2
username x9 password JMOSfRm7mx encrypted privilege 2
username x8 password kTTR8uWaa encrypted privilege 2
terminal width 80
Cryptochecksum:e65b29b7262d0c17d8610ec75d9351b6
: end
Posted by Martin Kayes on July 27, 2005, 8:45 am
I am surprised that the PIX didn't complain when you entered the last 3
static commands. The problem you have is that you are trying to static all
4 566x ports to the same inside port 5666,
What do you see for these 4 lines if you do a "show xlate" ?
Martin
> Hi,
> g.
> mypix# show run
> : Saved
> PIX Version 6.3(4)
> hostname mypix
> names
> 255.255.255.0
> 255.255.255.0
> pager lines 24
> mtu outside 1500
> mtu inside 1500
> pdm history enable
> arp timeout 14400
> 0 0
> 255.255.255.255 0 0
> 255.255.255.255 0 0
> 255.255.255.255 0 0
> 255.255.255.255 0 0
> 1:00:00
> http server enable
> floodguard enable
> telnet timeout 5
> ssh timeout 5
> console timeout 0
> terminal width 80
> : end
Posted by on July 27, 2005, 10:15 am
thanx for the quite response. could you elaborate a bit more what you
mean. i am a bit confused. the static commands are no difference than
say, port forwarding web traffic on port 80 to internal port 8088,
8081, 8088, etc... when i do a show xlate, it gives me the
translation, correctly. in this scenerio, i am asking all traffics
comming to x.x.112.147 or x.x.112.146 with destination port of 5666
5667 5668 5669 to point to internal hosts 10.10.0.3 10.10.0.4
10.10.0.5 10.10.0.6 to their ports 5666. what am i missing? is this
possible, or my syntex is incorrect..
thanx for your help.
Posted by Walter Roberson on July 27, 2005, 5:39 pm
:in this scenerio, i am asking all traffics
:comming to x.x.112.147 or x.x.112.146 with destination port of 5666
:5667 5668 5669 to point to internal hosts 10.10.0.3 10.10.0.4
:10.10.0.5 10.10.0.6 to their ports 5666. what am i missing? is this
:possible, or my syntex is incorrect..
You can't do that. Each inside IP+port can be statically mapped
to exactly one outside IP+port. Thus, you could have
x.x.112.146 5666 map to 10.10.0.3 5666 but then you have
"used up" 10.10.0.3 5666 and cannot -also- have x.x.112.147 5666
go to the same place.
Well... more than one mapping to an internal IP+port is possible,
but only by using policy nat or policy static, in which case the
remote machines IP+port can be part of the configuration. For example
you could have x.x.112.146 5666 map to 10.10.0.3 5666 usually,
but for source 22.33.44.55 you could have x.x.112.147 5666 map
there instead.
The important part to remember is that static mappings are
reversible, and you can't have a single inside IP+port map to two
different external IP+port (at least not without further qualification
of when the different mapping should be used.)
'The short version of what Walter said is "You have asked a question
which has no useful answer, please reconsider the nature of the
problem you wish to solve".' -- Tony Mantler
Posted by on July 27, 2005, 11:39 am
thank you for the quick response. let me be more clear. outsidide
connections to
x.x.112.147 with thd following destination ports:
x.x.112.147 :5666
x.x.112.147 :5667
x.x.112.147: 5668
x.x.112.147 5669
i want it to point to internal hosts
10.10.0.3 :5666
10.10.0.4 :5666
10.10.0.5 :5666
10.10.0.6 :5666
it does not seem to work.
i also tried telneting on the pix IP x.x.112.146 with the destination
ports and it also fails. howerver traffic to web, and ssh works on
x.x.112.147 to 10.10.0.101.
it may have something to do with "interface" in the static mapping
definition.
so i created the following maping and access_list
255.255.255.255
0 0
255.255.255.255 0 0
255.255.255.255 0 0
255.255.255.255 0 0
255.255.255.255 0 0
g.
Similar ThreadsPosted
cisco pix 515 port forwarding - NOT possible? hard to believe.. July 27, 2005, 12:23 am
Port Forwarding with Cisco 871?? September 25, 2005, 12:58 pm
Cisco 871 router port forwarding July 12, 2006, 8:41 pm
Cisco PIX 501 port forwarding trouble September 24, 2006, 10:32 am
port mapping or forwarding on Cisco Pix 506E August 5, 2005, 1:30 pm
Port forwarding from cisco 2600 to ASA-5510 July 20, 2006, 10:23 am
Port Forwarding / VPN Pass-Thru on a Cisco 2800 August 30, 2006, 3:20 pm
Cisco 2600 + DSL + Cable -> Failover and port forwarding July 2, 2008, 12:47 am
Port forwarding February 2, 2006, 3:05 pm
Port forwarding help? June 4, 2006, 10:23 pm
Need help Port forwarding on PIX 501 September 14, 2006, 9:18 am
Port 21 forwarding on PIX 501 September 15, 2006, 11:56 pm
PIX Port Forwarding November 15, 2006, 2:42 pm
port forwarding December 13, 2006, 9:39 am
Port Forwarding October 7, 2008, 9:36 am
