Can it be used as a terminal server, inaddition will it do basic console configurations?
- posted
16 years ago
~ Can it be used as a terminal server, inaddition will it do basic ~ console configurations?
Nope, the lines are all modems only, and can only connect to POTS lines, not to async serial lines.
Yep - I'd agree. You can't use this for anything other than dial out on a POTS line.
For what you want, you need NM-16A, NM-32A, NM-8A/S or NM-16A/S
Andrew
On Tue, 9 Oct 2007 21:31:14 +0100, Aaron Leonard wrote (in article ):
