hi I'm trying to establish a point to point Isdn connection , between two remote sites.
I even tried to attach an AT command string to the dialer , to reduce the Channel speed to 56k as follows :
chat-script isdn "" "atq1e0" OK "at&n38&w&y" int dialer 4 dialer string xxxxx modem-script isdn
the central site is Tel Aviv and the remote is NY USA.
does any one have any idea ? I've attached configuration and log from the USA site router. Thank's Ahiya zadok
tel aviv router
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory flash:c2800nm-advipservicesk9-mz.124-7.bin -- Version 12.4(4)T1
configuration
interface BRI1/3 description "Backup Dialers to France and USA" no ip address encapsulation ppp dialer pool-member 4 max-link 1 dialer pool-member 5 max-link 1 isdn switch-type basic-net3 ppp authentication chap callin ppp multilink
interface Dialer4 description "Backup Dialer to USA" ip address 172.30.1.1 255.255.255.252 encapsulation ppp dialer pool 5 dialer string xxxxxxx dialer-group 1 no cdp enable ppp authentication chap ppp chap hostname usename ppp chap password 0 123 ppp multilink
usa router
Cisco 1841 (revision 5.0) with 115712K/15360K bytes of memory. flash:c1841-entbase-mz.124-7.bin --- Version 12.4(7)
configuration
interface BRI0/0/0 ip address 172.30.1.2 255.255.255.252 encapsulation ppp dialer-group 1 isdn switch-type basic-ni ppp authentication chap ppp chap hostname user ppp chap password 0 123
sh log
*Jun 14 11:59:44 IDT: 0801015A080282D1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_SendPkt: Sending from L2 dest_id = 0, source_id = 522, prim = 241 priv_ln = 4, int_id = 1663282052 datastart = E750D428, netstart = E750D438, datasize = 24 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_DispPak: packet - start(E750D428), size (24) *Jun 14 11:59:44 IDT: 6323AB840000020A0241044200010920 *Jun 14 11:59:44 IDT: 0801015A080282D1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q921d: srl_send_l2_pak: source_id = Q.921 0x0000, dest_id = Q.931 0x0000, prim = DL_DATA_IND 0x0241 priv_len = 4 int_id = 0x6323AB84 datasize = 24 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q921d: data = *Jun 14 11:59:44 IDT: 6323AB84000000000241044200010920 *Jun 14 11:59:44 IDT: 0801015A080282D1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3IF_rx_L2_pak: received data *Jun 14 11:59:44 IDT: 0801015A080282D1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_SendprimPkt: source_id (0x20A), state (0x7), dest_id (0x200), event (0x140),sapi (0x0), ces (0x1), call_id (0x0), chan_id (0x0), int_id (0x6323AB84), free_p (0x1), pkt (0x63906E8C), msecs (0x0), priority (0xA)
*Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_SendPkt: source_id (0x20A), state (0x7), dest_id (0x200), event (0x140), sapi (0x0), ces (0x1), call_id (0x0), chan_id (0x0), int_id (0x6323AB84), free_pkt (0x1), pkt (0x634F3CA0), msecs (0x0), priority (0xA) *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_DispPak: packet - start(E750D438), size (4) *Jun 14 11:59:44 IDT: 0287013A *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_SendPkt: Sending from L2 dest_id = 0, source_id = 522, prim = 140 priv_ln = 4, int_id = 1663282052 datastart = E750D428, netstart = E750D438, datasize = 20 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: L2IF_DispPak: packet - start(E750D428), size (20) *Jun 14 11:59:44 IDT: 6323AB840000020A0140044200010920 *Jun 14 11:59:44 IDT: 0287013A *Jun 14 11:59:44 IDT: ISDN Q921d: isdn_l2d_srq_process: QUEUE_EVENT *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: handle_l2d_srq_mail: received: dest_id = 0, source_id = 522, prim = 140 priv_ln = 4, int_id = 1663282052, datasize = 4 line_status[0] = IF_ACTIVE *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q921f: User TX -> *Jun 14 11:59:44 IDT: 0287013A *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q921: User TX -> RR sapi=0 tei=67 nr=29 *Jun 14 11:59:44 IDT: ISDN Q921d: isdn_l2d_srq_process: event_count 1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: source 0x020A, event 0x005A, call id 0x int id 0x0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: event 0x5A cr_len 1 cr 129 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: call_id 0x47B0 cr 0x81 state 8 event 0x5A ces 1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_ProcessEvent: callref = 0x0081 RELEASE_COMP:Ux_ReleaseComp(nlcb) *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_state_change: callref 0x0081 old CONNECT_REQUEST, new NULL_STATE *Jun 14 11:59:44 IDT: ISDN BR0/0/0 CC: CCBRI_Go: source id 0x300, state 8, call id 0x47B0, event 0x341 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 CC: Decoded CC event 0x61C4AD70 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 CC: CCBRI_Go: call id 0x47B0 call ref 0x81 state 5 event 0x99 Src->L3 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 TGRM: get_tgrm_avail_state: idb 0x6323AB84 bchan 1 service_state 0 call_state 0 false busy 0x0 dsl 0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 TGRM: update_tgrm_call_status: idb 0x6323AB84 bchan 1 availability state 1 call state(prev,new) (2,0), dsl 0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 TGRM: update_tgrm_call_status: Calling TGRM with tgrm_call_isdn_update: idb 0x6323AB84 bchan 1 call state 0 call type 0 call dir 1 *Jun 14 11:59:44 IDT: ISDN EVENTd: cc_clear_free_list freeing 0x6390C84C *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x47B0 calltype 1 HOST_DISCONNECT_ACK *Jun 14 11:59:44 IDT: ISDN BR0/0/0 PACKET: process_rxstate: *Jun 14 11:59:44 IDT: 06000147B004080280D1080282D1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: process_rxstate: cause=0x51 (81), cause_present=1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x6323BE80, call_id=0x47B0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x6323F160, call_id=0x47B0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x6323F160, call_id=0x47B0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x6323BE80, call_id=0x47B0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: host_disconnect_ack: call type is DATA *Jun 14 11:59:44 IDT: ISDN BR0/0/0 EVENTd: isdn_report: callid 0x47B0 *Jun 14 11:59:44 IDT: %LINK-3-UPDOWN: Interface BRI0/0/0:1, changed state to down *Jun 14 11:59:44 IDT: ISDN Q921d: isdn_from_driver_process: QUEUE_EVENT *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q921f: User RX RR sapi=0 tei=67 nr=30 *Jun 14 11:59:44 IDT: ISDN Q921d: isdn_l2d_srq_process: event_count 1 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: source 0x020A, event 0x005A, call id 0x int id 0x0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: event 0x5A cr_len 1 cr 129 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 SERROR: L3_GetUser_NLCB: EVENT 0X5A No NLCB 2 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x81 callid 0x0 *Jun 14 11:59:44 IDT: ISDN BR0/0/0 Q931d: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x81 ev 0x5A ces 1 -- Message ignored
