Cisco inbound NAT Question
Having an issue, Trying to interconnect a Extreme networks Blackdiamond 8810 and a 6504 cisco via 10gb fiber. We need to NAT everything from the BD8810 to the 6504... but extreme networks doesnt support NAT... Is there anyway to do an inbound nat on the Single interface of the 6504?
Thanks
Devin Shirkey
Errr... Configure it?
At 10G you would want to be sure that the NATing is done in hardware. From memory I think it can be.
Obviously you need to be using the interfaces (physical or SVI) in L3 mode. As far as I know no cisco kit does NAT on L2 interfaces.
bod43
We have layer 3 working between the devices and have static route on the cisco side for one subnet on the BD side. Everything is working. The only problem we run into is we both have a large network. They are the county in which my city (that I work for) resides in, and they will also be connecting to about 8 other cities. If we start putting routes out there on the Cisco ring, we are going to run into a problem where someone else has the same subnet, thats why we wanted to do NAT, but I cannot do NAT over to the Cisco... Could cisco do an inbound NAT? or maybe NAT on a loopback interface first?
Thanks
Devin Shirkey
Yes, I would think so.
If you want configuration advice you need to be more specific. There are many kinds of NAT and you need to provide information to indicate which will be most suitable. There may well be a limit on the number of NATs that can be supported in hardware and 8 cities sounds like it might be a lot.
Also hardware and software specifics might be useful. sh ver sh mod !
bod43
