I downloaded AP340v1205.exe (firmware file) Size: 1526.61 KB from cisco but the unzipped img file will not write onto a standard MF-2HD floppy disc. I also tried AP340v1204.exe Size: 1516 KB but still got the same problem - the write process fails. I've tried different floppy discs with different extraction programs (also tried rawrite but the process failed again) in both windows and DOS on two different PC's but no luck. I used Floppy Image to check the integrity of the img files and the program said 'CRC32 check failed'. How do I get these images onto a floppy disc?
- posted
15 years ago
