Hello I have always used cisco's DHCP inside the routers without trouble.
Now I am in this particular situation:
Cisco 837 IOS 12.4(25c)
Eth0: Office LAN 192.168.0.0/24 eth2: WISP Lan 172.16.0.1/23 (255.255.254.0)
These are the relevant lines of the config:
no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.0 192.168.1.10 ip dhcp excluded-address 192.168.1.20 192.168.1.254 ip dhcp excluded-address 172.16.0.0 172.16.0.254 ip dhcp excluded-address 172.16.1.1 172.16.1.99 ! ip dhcp pool Mezzogori network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 netbios-node-type h-node domain-name mezzogorimario.local dns-server 192.168.1.1 ! ip dhcp pool WISP-TEST network 172.16.0.0 255.255.254.0 default-router 172.16.0.1 netbios-node-type h-node domain-name wisp-test.local dns-server 172.16.0.1 ! ! ip cef
interface Ethernet0 description Rete 192.168.1.0/24 Office ip address 192.168.1.1 255.255.255.0 no ip redirects no ip proxy-arp ip nat inside ip virtual-reassembly hold-queue 100 out ! interface Ethernet2 description Rete 172.16.0.0/23 WISP TEST ip address 172.16.0.1 255.255.254.0 ip access-group 110 in no ip redirects no ip proxy-arp ip nat inside ip virtual-reassembly hold-queue 100 out
The access list 110 is the following:
access-list 110 deny ip 172.16.0.0 0.0.1.255 192.168.1.0 0.0.0.255 access-list 110 deny udp 172.16.0.0 0.0.1.255 any eq tftp access-list 110 deny tcp 172.16.0.0 0.0.1.255 any eq 135 access-list 110 deny udp 172.16.0.0 0.0.1.255 any eq 135 access-list 110 deny tcp 172.16.0.0 0.0.1.255 any range 137 139 access-list 110 deny udp 172.16.0.0 0.0.1.255 any range netbios-ns netbios-ss access-list 110 deny tcp 172.16.0.0 0.0.1.255 any eq 445 access-list 110 deny udp 172.16.0.0 0.0.1.255 any eq 445 access-list 110 deny tcp 172.16.0.0 0.0.1.255 any eq 593 access-list 110 deny udp 172.16.0.0 0.0.1.255 any eq 593 access-list 110 deny tcp 172.16.0.0 0.0.1.255 any eq 4444 access-list 110 deny udp 172.16.0.0 0.0.1.255 any eq 4444 access-list 110 permit ip 172.16.0.0 0.0.1.255 any
To avoid that the wisp network enters the eth0 network. to avoid some outgoing worms
I think that I am blocking DHCP requests...
Can someone help me?
