Cisco 1841 with Adv. IP
I'm having some trouble getting cisco's dhcp to work well in a mixed environment with windows and linux. Here is the problem, (which I understand also exists with ISC's dhcp aswell). I want to assign static addresses to several machines, some of which dual boot windows and linux. In the cisco config I would put something like this:
ip dhcp pool GUEST network 10.0.10.0 255.255.255.0 domain-name guest.tld dns-server 65.106.1.196 65.106.7.196 default-router 10.0.10.1
ip dhcp pool testpool host 10.0.0.38 hardware-address 0019.bbd7.fed7 default-router 10.0.0.2 dns-server 10.0.0.50
Using the above config, the linux box gets it's correct IP as expected. When I reboot into windows, I get thrown onto the guest ip block. Apparently for windows hosts, you must use client-identifier rather then hardware address. It's the same thing, but prefixed with a 01 to represent ethernet.
ip dhcp pool testpool host 10.0.0.38 hardware-address 0100.19bb.d7fe.d7 default-router 10.0.0.2 dns-server 10.0.0.50
Now the windows box can get an IP, but rebooting into linux throws you into the guest pool.
I contacted cisco, who's response was to make two pools for every host. one with hardware-address and the other with client-identifier, and set the lease time to be extremely short. While that sounded rediculous, I tried it anyway. The router won't allow you to specify two bindings with the same ip... What is the proper way to do this?? Am I going to have to get a cheap linksys router, and let that handle dhcp ?
Below is my current config: ip dhcp pool testpool origin file tftp://10.0.10.100/1841-dhcp.txt default-router 10.0.0.2 dns-server 10.0.0.50
and the file 1841-dhcp.txt:
*time* Jul 07 2007 01:17 PM *version* 2 !IP address Type Hardware address Lease expiration 10.0.0.39 /24 1 0019.bbd7.fed7 Infinate 10.0.0.39 /24 id 0100.19bb.d7fe.d7 *end*And the console output when the cisco loads that file:
000194: *Jul 5 14:21:41.291 PCTime: DHCPD: reading bindings from tftp://10.0.10.100/1841-dhcp.txt. 000195: *Jul 5 14:21:41.299 PCTime: DHCPD: read 217 / 1024 bytes. 000196: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "*time* Jul 07 2007 01:17 PM" 000197: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "*version* 2" 000198: *Jul 5 14:21:41.299 PCTime: DHCPD: route: Parsed version = 2 000199: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "!IP address Type Hardware address Lease expiration" 000200: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "10.0.0.39 /24 1 0019.bbd7.fed7 Infinate" 000201: *Jul 5 14:21:41.299 PCTime: DHCPD: creating binding for 10.0.0.39 000202: *Jul 5 14:21:41.299 PCTime: DHCPD: Adding binding to radix tree (10.0.0.39) 000203: *Jul 5 14:21:41.299 PCTime: DHCPD: Adding binding to hash tree 000204: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "10.0.0.39 /24 id 0100.19bb.d7fe.d7" 000205: *Jul 5 14:21:41.299 PCTime: DHCPD: binding for 10.0.0.39 already exists. 000206: *Jul 5 14:21:41.299 PCTime: DHCPD: parsing text line "*end*" 000207: *Jul 5 14:21:41.303 PCTime: DHCPD: read static bindings from tftp://10.0.10.100/1841-dhcp.txt.
