Dear All,
Has anyone configured a Cisco Catalyst 2950 that is connected over LAN to an ISP with two subnet? For example, my current configuration has an IP Address of 211.58.141.XXX 255.255.255.224 and another IP Address of 201.32.48.XXX 255.255.255.224 but we are already connected over a CAT 5 using VLAN1 in my configuration and having a ip default-gateway of 211.58.141.1. The problem is that the Cisco Catalyst 2950 can only have one ip default-gateway, how can I setup the Cisco Catalyst 2950 to use both of the IP Address to the same ISP? Many thanks!
Regards, Kengie
