I got myself a Cisco IOS Wide-Area Networking Command Reference Guide, looks great.... One problem left (could not find it in te reference). The reference guide explaines a lot of (ATM) interface tuning, my problem is (I came down from GUI interface management to CLI) I don't know how to create an additional ATM interface! ATM interface ATM0 does exist, but what I need are additional interface like ATM0.1 and ATM0.2. Tuning those interfaces isn't the problem, I just can't enter them, because they don't exist. How to create? Thanks in advance!
"Doug McIntyre" schreef in bericht news:4bf2f4da$0$633$ snipped-for-privacy@newsreader.iphouse.net...
Doug,
Thanks for your reply, but that isn't working. I'll receive an error pointing to the first number behind the 'int atm 3/0' command. Does not recognize the command....Don't know what to do..
Here my running config. Remember, the first PVC (ATM0.1) was created trough a GUI interface, but the GUI does not allow to create more then one PVC....so I had to switch to CLI.... :(
cisco800#show run Building configuration...
Current configuration : 3962 bytes ! ! Last configuration change at 23:14:50 UTC Fri Mar 1 2002 by admin ! version 15.1 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname cisco800 ! boot-start-marker boot-end-marker ! no logging buffered ! aaa new-model ! ! aaa authentication login default local ! ! ! ! ! aaa session-id common memory-size iomem 10 ! crypto pki trustpoint TP-self-signed-3977281076 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-3977281076 revocation-check none rsakeypair TP-self-signed-3977281076 ! ! crypto pki certificate chain TP-self-signed-3977281076 certificate self-signed 01 30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 33393737 32383130 3736301E 170D3032 30333031 30303235 31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373732 38313037 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100BA91 F2BABFB1 2C3FBFE6 0413C374 B8CEC0B7 165EE17B 7BA146B5 01E75652 C80AD669 A5F7E426 23CC692E 58D174B0 CDD1AF57 A6E9BE05 2465771C DCF29C4A C3C3532A 62DDE538 6BD98D81 4B4F6860 BCEA0BBC D099DE4A 34185631 7D202243 4DC86748 DB5FF94B ADF0963F CCA679F8 F95D59CA 9636B17D 713E4F57 84AF788C FD5F0203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603 551D1104 0C300A82 08636973 636F3830 30301F06 03551D23 04183016 8014050A quit ip source-route ! ! ip dhcp excluded-address 192.168.10.1 192.168.10.99 ip dhcp excluded-address 192.168.10.151 192.168.10.254 ip dhcp excluded-address 192.168.2.1 192.168.2.99 ip dhcp excluded-address 192.168.2.151 192.168.2.254 ! ip dhcp pool Pool1 import all network 192.168.10.0 255.255.255.0 dns-server 213.144.235.1 213.144.235.2 default-router 192.168.10.200 ! ip dhcp pool ccp-pool1 network 192.168.2.0 255.255.255.0 dns-server 213.144.235.1 213.144.235.2 default-router 192.168.2.200 ! ! ip cef ! ! license udi pid CISCO867-K9 sn *********** ! archive log config hidekeys username root privilege 15 secret 5 ***** username admin privilege 15 secret 5 **** ! ! ! ! ! ! ! ! ! interface ATM0 no ip address no atm ilmi-keepalive ! interface ATM0.1 point-to-point pvc 0/35 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet0 switchport access vlan 2 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Vlan1 ip address 192.168.10.200 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan2 ip address 192.168.2.200 255.255.255.0 ! interface Dialer0 ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication pap callin ppp pap sent-username **** password 0 ******* ! ip forward-protocol nd ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! ip nat inside source list 1 interface Dialer0 overload ! access-list 1 remark INSIDE_IF=Vlan1 access-list 1 remark CCP_ACL Category=2 access-list 1 permit 192.168.10.0 0.0.0.255 dialer-list 1 protocol ip permit ! ! control-plane ! ! line con 0 no modem enable line aux 0 line vty 0 4 transport input all ! scheduler max-task-time 5000 end
As you don't have an interface atm3/0 you won't be able to put subinterfaces there. Which ATM-Inteface do you have? How does the first ATM-IF look like? When you have learned the logic, then you can create new subinterfaces.
You even wrote down the right interface (atm0.2), so just type away! Note that the number of subinterfaces you can create also depends upon IOS-Version (you can't go on indefinitely)
(note, hardly anybody here would be using the GUI, we wouldn't know what it does..).
Your first subinterface is a point-to-point, not multipoint. Point-to-point implies that you are deploying only one, thus the CLI is most likely preventing you from doing more since your first subinterface is a point-to-point.
Get rid of that PVC and redo it as a multi-point and you'll probably be able to add more subinterfaces (as additional multi-points).
