Cisco Aironet 1240AG WPA/WPA2?
Hi
I have a Cisco Aironet 1240AG which we were planning on using for our wireless network. According to the specs, it should be capable of WPA2, but on the web interface, only WPA is marked.
Does anyone know why? It was only purchased a few months ago.
Thanks!
smokejo
~ Hi ~ ~ I have a Cisco Aironet 1240AG which we were planning on using for our ~ wireless network. According to the specs, it should be capable of WPA2, ~ but on the web interface, only WPA is marked. ~ ~ Does anyone know why? It was only purchased a few months ago. ~ ~ Thanks!
The AP1240AG series AP supports both WPA1 (TKIP) and WPA2 (AES-CCM), with both PSK and EAP authentication. Here is an example of configuring WPA2 on it:
Regards,
Aaron
Aaron Leonard
Hi, I'm deploying a Wireless Network in a newly built Hotel. Each floor has
26 rooms and all the walls are 6inches of cast concrete I'm considering using a Cisco Aironet 1240AG on each floor in combination with an amplifier and External Antennae from
Do any of you have prior experience with such a deployment and do you have any advice/suggestions? Would really appreciate it? Thanks in advance
OldManChild
~ Hi, ~ I'm deploying a Wireless Network in a newly built Hotel. Each floor has ~ 26 rooms and all the walls are 6inches of cast concrete ~ I'm considering using a Cisco Aironet 1240AG on each floor in ~ combination with an amplifier and External Antennae from ~
~ Do any of you have prior experience with such a deployment and do you ~ have any advice/suggestions? Would really appreciate it? ~ Thanks in advance
Probably the only way to make this work, with just one AP per floor, would be to use leaky coax for your antenna ... snake the leaky coax above all the rooms. This would not be Cisco TAC supported, RF-wise (we only support Cisco brand antennas), but it might work.
We would prefer that you mount an AP above each room ;)
Cheers,
Aaron
Aaron Leonard
Your idea of the leaky cable is sound, but one needs to remember that this solution also comes at the cost of the leaky cable being kind of lossy, hence more power will need to be transmitted. In the cellular world we use bidirectional amps for this purpose.
Dana
