Cisco Aironet 1231AG Access Point.
I have Cisco Aironet 1231AG access point running Cisco IOS 12.2(13)JA1 Early Deployment Software (fc1).It currently does not support WPA2, however it does suport WPA. I am planning to update the Cisco IOS to
12.3.x that will allow the access point to support WPA2 according to Cisco documentation. However, at the Cisco download site for Cisco Aironet 1200 series access points, there is a Cisco IOS upgrade for Cisco Aironet 1230 to support WPA2, but not Cisco Aironet 1231AG as this model number is not listed under the Cisco Aironet 1200 series. If I download the Cisco IOS version for the Cisco Aironet 1230AG and install it on the Cisco Aironet 1231AG, will this crash my access point? Please any information will be greatly appreciated and thank you very much in advance. NB: The exact model number for the access point is AIR-AP1231G-A-K9.
Benchmark.
benchmark
from my 1231G-K-A9:
AP1#sh version Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEA, RELEASE S OFTWARE (fc2) Technical Support:
(c) 1986-2006 by Cisco Systems, Inc. Compiled Wed 23-Aug-06 16:42 by kellythw
ROM: Bootstrap program is C1200 boot loader BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RE LEASE SOFTWARE (fc1)
AP1 uptime is 0 minutes System returned to ROM by power-on System image file is "flash:/c1200-k9w7-mx.123-8.JEA/c1200-k9w7-mx.
123-8.JEA"
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision A0) with
15138K/12 36K bytes of memory. Processor board ID FOC074510TT PowerPC405GP CPU at 196Mhz, revision number 0x00C4 Last reset from power-on 1 FastEthernet interface 1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:0E:83:04:67:D6 Part Number : 73-8704-05 PCA Assembly Number : 800-23211-06 PCA Revision Number : A0 PCB Serial Number : FOC074510TT Top Assembly Part Number : 800-23304-05 Top Assembly Serial Number : FHK0746J3R4 Top Revision Number : B0 Product/Model Number : AIR-AP1231G-A-K9
Configuration register is 0xF
AP1#
Merv
You should download "1200 WIRELESS ACCESS POINT" software (c1200-k9w7-tar.123-8.JEB1.tar). This works.
make
quoted text -
Hi Make, Do you mean this Cisco IOS running on Cisco Aironet 1231G supports WPA2?
Thanks in advance, Eric.
benchmark
quoted text -
Yes it does.
make
