Hi.
Our main router at one of our site was having problems with dropping the ADSL connection on a regular basis so I got onto BT and they ran some tests on the line a said that there was some unkown interferance on the line causing the connection to drop. Around the time of them testing the line the connection totally dropped and has not been connected since. BT came to site and and found that there was a "loose connection in the master socket" and it was damp too - which must have been causing the interferance. They connected their modem and everything was working fine.
We plugged our router back in and nothing! Ive done some investigation and run some commands on the router and it seems the router is unable to see the ADSL on the line - see below.
Can anyone make any suggestions of anything to try? Could there be a problem with the router now?
Cheers
Jon
#show dsl int atm0 ATM0 Alcatel 20190 chipset information Line has not yet been activated. No information available. DSL: Training log buffer capability is not enabled
#show int atm0 ATM0 is initializing, line protocol is down Hardware is MPC ATMSAR (with Alcatel ADSL Module) MTU 4470 bytes, sub MTU 4470, BW 4608 Kbit, DLY 80 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ATM, loopback not set Encapsulation(s): AAL5 AAL2, PVC mode 10 maximum active VCs, 1024 VCs per VP, 0 current VCCs VC Auto Creation Disabled. VC idle disconnect time: 300 seconds Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: Per VC Queueing 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer#debug atm events
000873: *May 7 11:05:34.194 PCTime: DSL(ATM0): Received 1 timer events during wait 000874: *May 7 11:05:36.694 PCTime: DSL(ATM0): Received 2 timer events during wait 000875: *May 7 11:05:39.194 PCTime: DSL(ATM0): Received 3 timer events during wait 000876: *May 7 11:05:41.694 PCTime: DSL(ATM0): Received 4 timer events during wait 000877: *May 7 11:05:44.194 PCTime: DSL: No response from init_AMR- R-2.5.042_no_bist.bin 000878: *May 7 11:05:44.194 PCTime: DSL: Unexpected response 0x0 to init_AMR-R-2.5.042_no_bist.bin 000879: *May 7 11:05:44.194 PCTime: DSL: SM: [DMTDSL_DLOAD_1 ->DMTDSL_INIT]
000880: *May 7 11:05:44.266 PCTime: DSL: SM: [DMTDSL_INIT ->DMTDSL_DLOAD_1]
000881: *May 7 11:05:44.266 PCTime: DSL: Downloading init_AMR- R-2.5.042_no_bist.binretry=0, reg=0x1 retry=1, reg=0x1 retry=2, reg=0x1 000882: *May 7 11:05:44.290 PCTime: DSL: Could not send command 0x12 after 3 retries 000883: *May 7 11:05:44.290 PCTime: send command fails!!! 000884: *May 7 11:05:44.290 PCTime: DSL: Could not download init_AMR- R-2.5.042_no_bist.bin
