Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by randalf on January 26, 2006, 2:00 pm
Please log in for more thread options one of the four ethernet interfaces on my cisco 837 cheers for any info | |||||||||||||||||||
Posted by Peter on January 26, 2006, 7:53 pm
Please log in for more thread options Dare I ask, but why would anyone want to do this and chuck away 90% of the capability of the 837? In theory yes it can be done, but there can be a lot of if's, buts and "it all depends" in getting it working. Unless you have a real burning need to do this, I would strongly recommend using the NAT capabilities of the Router, you lose nothing and gain a heap of other options... In simple terms, you would need to BRIDGE your WAN data to the Ethernet, but that almost completely removes the ability to use the 837 to do anything intelligent. The bottom line is that configuring this depends on quite a bit more technical detail from your ISP about exactly HOW they are delivering their service to you and exactly what you want to do with it Cheers.........pk. -- Peter from Auckland. | |||||||||||||||||||
Posted by Walter Roberson on January 26, 2006, 11:20 pm
Please log in for more thread options >it is possible to assign the static ip address given to me by my adsl isp to
>one of the four ethernet interfaces on my cisco 837 There is some specialized commercial (e.g., hotel) equipment that the below does not apply to, but other than that: For a router, any particular IP address range can be either routed or bridged. If the IP address *range* is routed, then it can appear on exactly one of the interfaces; if it is bridged, then the bridged interfaces act as a switch, with a single logical routing layer applied to the aggregate. Either way, you cannot have an IP address assigned to one interface, and a distinct IP address of the same subnet assigned to a different interface. You have about three choices: A) "Don't do that!" B) subnet the IP address range, and negotiate with the ISP so that it routes the entire range to you but that the link to the ISP uses a subnet. For example, ISP routes all of 123.45.67.80/255.255.255.240 to you, but the link with the ISP uses 123.45.67.81/255.255.255.248 on your side and 123.45.67.82/255.255.255.248 on their side, and you then assign the 123.45.67.88/255.255.255.248 subnet to the second interface C) have the ISP route the entire subnet to you, but arrange with the ISP so that that is layered on top of a distinct /30. For example, the ISP routes all of 123.45.67.80/255.255.255.240 to you, but it does that over 111.122.133.144/255.255.255.252 with the ISP taking 111.122.133.145/255.255.255.252 and you taking 111.122.133.146/255.255.255.252 for your end of the link. You then do whatever you want internally with 123.45.67.80/255.255.255.240, subnetting it (perhaps with different sized subnets) over your various interfaces. One of the suboptions of A) "Don't do that!" is to use NAT on your router (or firewall) to accept the additional public IPs "as is" and to translate them into different internal IP addresses that might happen to internally be on different interfaces. If your ADSL ISP operates like my cable ISP, then their offer to sell you additional static IP addresses is probably mostly a crock. Hereabouts, on anything less than the "Premium Business Package", additional static IPs cost $C20 per month -each- (residential connection itself: $C40/month). The cable ISP here does not assign a subnet to you and does not route the static IPs over a carrier IP (such as to your firewall): instead, the ISP watches for DHCPs from distinct MAC addresses reaching your cable modem, and does static DHCP mapping for the MACs. This kind of situation is useless if you are running a router or firewall: the only thing it works for is if you have a hub or switch connected to the ISP modem and all of your devices sit "raw" on the hub/switch and are not even LAN'd together [unless it be via seperate NICs for that purpose.] You can't even put in a firewall and proxy-arp for the static IP addresses, not unless you manage to find a firewall that will bother to DHCP via distinct MACs for the multiple outside addresses (which is not something you can do in IOS or PIX.) | |||||||||||||||||||
Posted by Uli Link on January 28, 2006, 5:51 am
> one of the four ethernet interfaces on my cisco 837 With IOS 12.3(8)YG3, 12.3(14)T or 12.4 you have a fully routable Ethernet2 interface on the physical FastEthernet Port4. DMZ or WAN backup. The FastEthernet Ports of the 83x series is layer2 only. You cannot assign IP addresses. You can set a ports speed and duplex settings. -- Uli | |||||||||||||||||||
| Similar Threads | Posted |
| Cisco VPN issues | August 2, 2005, 6:30 pm |
| cisco 837 ip issues | January 26, 2006, 2:00 pm |
| Cisco 5300 issues | March 17, 2006, 12:52 pm |
| Cisco VPN Client Issues | November 28, 2005, 4:23 pm |
| cisco pix VPN routing issues | February 26, 2007, 1:13 pm |
| Cisco VPN Client issues with PIX 506e | September 14, 2006, 12:14 pm |
| Cisco Pix 501 Very Strange issues ! Newbie needs help !! | October 4, 2006, 3:14 am |
| cisco 2811 lan port config issues | January 26, 2006, 4:36 am |
| Citrix MetaFrame / Cisco Router issues | July 7, 2005, 8:25 am |
| Cisco IOS Firewall Issues with Windows Update | January 21, 2007, 9:38 am |
| Cisco 2611 router interface issues | February 8, 2008, 5:42 pm |
| Cisco 1760 router and VPN client Connection Issues | January 6, 2008, 5:47 am |
| Connecting to a Cisco router's Console port via Zterm - Issues | August 1, 2007, 1:21 am |
| Connecting to a Cisco router's Console port via Zterm - Issues | August 1, 2007, 1:36 am |
| Speed/Throughput Issues ADSL/Cable Modem to Cisco Router | June 6, 2006, 10:08 am |
cisco 837 ip issues
Yahoo!
Windows Live
del.icio.us
digg
Netscape
