Hi ilya
Thanks for the reply i have configured the router accordingly .here is the configuration
no aaa new-model ip subnet-zero ! ! ip inspect name ethernetin cuseeme timeout 3600 ip inspect name ethernetin ftp timeout 3600 ip inspect name ethernetin h323 timeout 3600 ip inspect name ethernetin http timeout 3600 ip inspect name ethernetin rcmd timeout 3600 ip inspect name ethernetin realaudio timeout 3600 ip inspect name ethernetin smtp timeout 3600 ip inspect name ethernetin sqlnet timeout 3600 ip inspect name ethernetin streamworks timeout 3600 ip inspect name ethernetin tcp timeout 3600 ip inspect name ethernetin tftp timeout 30 ip inspect name ethernetin udp timeout 15 ip inspect name ethernetin vdolive timeout 3600 ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! crypto isakmp policy 1 encr 3des hash md5 authentication pre-share group 2 crypto isakmp key 0 xxxxx address a.b.c.d ! ! crypto ipsec transform-set unionset esp-3des esp-md5-hmac ! crypto map union 1 ipsec-isakmp set peer a.b.c.d set transform-set unionset match address 101 ! ! ! ! interface Ethernet0 ip address 192.168.2.1 255.255.255.0 ip nat inside hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive pvc 0/50 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto hold-queue 224 in ! interface FastEthernet1 no ip address duplex auto speed auto ! interface FastEthernet2 no ip address duplex auto speed auto ! interface FastEthernet3 no ip address duplex auto speed auto ! interface FastEthernet4 no ip address duplex auto speed auto ! interface Dialer1 ip address negotiated ip nat outside encapsulation ppp dialer pool 1 dialer-group 2 ppp authentication pap callin ppp pap sent-username xxxxxx password xxxxx crypto map union ! ip nat inside source route-map nonat interface Dialer1 overload ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip http server no ip http secure-server ! access-list 1 permit 192.168.0.0 0.0.0.255 access-list 1 permit 192.168.2.0 0.0.0.255 access-list 1 permit 192.168.4.0 0.0.0.255 access-list 101 permit ip 192.168.2.0 0.0.0.255 10.10.10.0 0.0.0.255 access-list 101 deny ip 192.168.2.0 0.0.0.255 any access-list 102 permit icmp any any unreachable access-list 102 permit icmp any any echo-reply access-list 102 permit icmp any any packet-too-big access-list 102 permit icmp any any time-exceeded access-list 102 permit icmp any any traceroute access-list 102 permit icmp any any administratively-prohibited access-list 102 permit icmp any any echo access-list 102 permit esp any any access-list 102 permit udp any any eq isakmp access-list 102 deny ip any any access-list 120 deny ip 192.168.2.0 0.0.0.255 10.10.10.0 0.0.0.255 access-list 120 permit ip 192.168.2.0 0.0.0.255 any dialer-list 2 protocol ip permit route-map nonat permit 10 match ip address 120 ! ! line con 0 exec-timeout 120 0 no modem enable stopbits 1 line aux 0 line vty 0 4 exec-timeout 120 0 password 7 011F0F0E5A040B5C731D login ! scheduler max-task-time 5000
But istill not able to establish the connection here is the debug output
Mar 1 00:28:51.803: ILMI(ATM0): Sending ilmiColdStart trap
*Mar 1 00:28:51.803: ILMI(ATM0): No ILMI VC found
*Mar 1 00:28:51.803: ILMI: Encapsulation error on o/g ILMI Pdu (ATM0)
*Mar 1 00:28:51.803: ILMI: Unable to Send Pdu out
*Mar 1 00:28:52.895:
*Mar 1 00:28:52.895: RX interrupt: conid =3D 3, rxBd =3D 0x3A00=FDx1 0x1
0x4 0x2
*Mar 1 00:28:52.903: Vi2 PPP: I pkt type 0x0021, datagramsize 50 link[ip]um=3D=F1
*Mar 1 00:28:52.903: IPpacketQ deq: s=3D217.164.55.150 (Dialer1), d=3D217.164.181.8, flags=3D0x280, tos=3D0x0, frag_offset=3D0
*Mar 1 00:28:52.903: TCP src=3D4943, dst=3D445, seq=3D2537213782, ack= =3D0, win=3D65535 SYN
*Mar 1 00:28:52.903: IP: s=3D217.164.55.150 (Dialer1), d=3D217.164.181.8, len 48, rcvd 1
*Mar 1 00:28:52.911: tcp0: I LISTEN 217.164.55.150:4943
217.164.181.8:445 seq 2537213782 OPTS 8 SYN WIN 65535
*Mar 1 00:28:52.911: TCP: connection attempt to port 445
*Mar 1 00:28:52.911: TCP: sending RST, seq 0, ack 2537213783
*Mar 1 00:28:52.911: TCP: sent RST to 217.164.55.150:4943 from
217.164.181.8:445
*Mar 1 00:28:52.911: IP ARP: creating incomplete entry for IP address:
217.164.55.150 interface Dialer1
*Mar 1 00:28:52.915: IP ARP: sent req src 217.164.181.8
0012.807b.3967, dst 217.164.55.150 0000.0000.0000 Dialer1
*Mar 1 00:28:52.915: Di1 DDR: bridge (0x0806), 42 bytes, outgoing interesting (pppox over dialer)
*Mar 1 00:28:52.915: DDR: FFFFFFFF FFFF0012 807B3967 08060001 08000604
00010012
*Mar 1 00:28:52.919: DDR: 807B3967 D9A4B508 00000000 0000D9A4 3796
*Mar 1 00:28:52.919: Di1 DDR: dialer_fsm_up()
*Mar 1 00:28:52.919: Vi2 PPP: Outbound bridge packet dropped, BCP state is Listen
*Mar 1 00:28:52.919: IP ARP: sent req src 192.168.2.1 0012.807b.3967, dst 217.164.55.150 0000.0000.0000 Ethernet0
*Mar 1 00:28:53.499:
*Mar 1 00:28:53.499: RX interrupt: conid =3D 3, rxBd =3D 0x3A0053C, status =3D 0x1C20, length=3D94
*Mar 1 00:28:53.499: process_receive_packet: vcnum=3D1 encty 0xA2 0xD9
0xA4 0xB5 0x8 0x27 0x17 0x1A 0xE1 0x0 0x48 0xC9 0x3F 0xD9 0x9A 0xAD
0x98 0x3E 0xBA 0x10 0x82 0x0 0x0 0x4 0x6 0xB8 0x2F 0x67 0x73 0xD 0x0
0x0 0x0 0x0 0xD 0x4 0x91 0x35 0x3A 0xA2 0xD6 0xC5 0x9E 0xB3 0xA6 0xAB
0x0 0x0 0x1 0x9 0xA2 0xA3 0xA8 0x3B 0x14 0xED 0x42 0x79 0x4C 0x90 0x6A
0x71 0xDE 0x3E 0x9 0x6C 0x94 0xDF 0xBD 0x9B 0x19 0xF4 0x96 0x24 0x31
0x2 0x1E
*Mar 1 00:28:53.523: Vi2 PPP: I pkt type 0x0021, datagramsize 94 link[ip]
*Mar 1 00:28:53.523: IPpacketQ deq: s=3D145.53.58.162 (Dialer1), d=3D217.164.181.8, flags=3D0x280, tos=3D0x0, frag_offset=3D0
*Mar 1 00:28:53.523: UDP src=3D10007, dst=3D6881
*Mar 1 00:28:53.523: IP: s=3D145.53.58.162 (Dialer1), d=3D217.164.181.8, len 92, rcvd 1
*Mar 1 00:28:53.523: UDP: rcvd src=3D145.53.58.162(10007), dst=3D217.164.181.8(6881), length=3D72
*Mar 1 00:28:53.523: ICMP: dst (217.164.181.8) port unreachable sent to 145.53.58.162
*Mar 1 00:28:53.523: IP ARP: creating incomplete entry for IP address:
145.53.58.162 interface Dialer1
*Mar 1 00:28:53.527: IP ARP: sent req src 217.164.181.8
0012.807b.3967, dst 145=AE
*Mar 1 00:28:53.531: DDR: 807B3967 D9A4B508
00000000 00009135 3AA2
*Mar 1 00:28:53.535: Di1 DDR: dialer_fsm_up()
*Mar 1 00:28:53.535: Vi2 PPP: Outboun=FC8:53.703: Vi2 LCP-FS: I ECHOREQ [Open] id 22 len 8 magic 0x7FC57344
*Mar 1 00:28:53.703: Vi2 LCP-FS: O ECHOREP [Open] id 22 len 8 magic
0x12893103 dst 145.53.58.162 0000.0000.0000 Ethernet0
*Mar 1 00:28:53.539: IP: s=3D145.53.58.162 (Dialer1), d=3D217.164.181.8, len 92, dispose udp.noport
*Mar 1 00:28:53.703: RX interrupt: conid =3D 3, rxBd =3D 0x3A00548, status =3D 0x1C20, length=3D=F9
*Mar 1 00:28:53.707: c820_aal_send: pak =3D 0x813486A4, vc =3D 1, q =3D 1
*Mar 1 00:28:53.707: pquicc_sar_pak2txring: nextTxBd =3D 0x8171EF30, ring =3D 0x81204644
*Mar 1 00:28:53.707: pquicc_sar_add_pak_tx: packet TX=3D0x39C44A0, len=3D10, oam?=3D0
*Mar 1 00:28:53.707: TX interrupt: conid 3, usedTxBd: Shadow
0x8171EF30, Real 0x3A00F90
*Mar 1 00:28:53.707: pquicc_sar_safe_start: vc =3D 1
*Mar 1 00:28:53.803: ILMI(ATM0): Sending ilmiColdStart trap
*Mar 1 00:28:53.803: ILMI(ATM0): No ILMI VC found
*Mar 1 00:28:53.803: ILMI: Encapsulation error on o/g ILMI Pdu (ATM0)
*Mar 1 00:28:53.803: ILMI: Unable to Send Pdu out
*Mar 1 00:28:55.331:
*Mar 1 00:28:55.331: RX interrupt: conid =3D 3, rxBd =3D 0x3A00554, status =3D 0x1C00, length=3D50
*Mar 1 00:28:55.335: process_receive_packet: vcnum=3D1 enctype=3D9
*Mar 1 00:28:55.335: Virtual-Access2: copy pkt, tmp->flags 0x280, idb->encsize 2
*Mar 1 00:28:55.335: size 50
0x0 0x21 0x45 0x0 0x0 0x30 0xBC 0xC1 0x40 0x0 0x6D 0x6 0xFE 0xED 0xC4
0xCA 0xFE 0xA0 0xD9 0xA4 0xB5 0x8 0xB 0xB4 0x1A 0xE1 0x43 0x77 0xF4
0x92 0x0 0x0 0x0 0x0 0x70 0x2 0xFA 0xF0 0xD7 0x76 0x0 0x0 0x2 0x4 0x5
0xB4 0x1 0x1 0x4 0x2
*Mar 1 00:28:55.343: Vi2 PPP: I pkt type 0x0021, datagramsize 50 link[ip]
*Mar 1 00:28:55.343: IPpacketQ deq: s=3D196.202.254.160 (Dialer1), d=3D217.164.181.8, flags=3D0x280, tos=3D0x0, frag_offset=3D0
*Mar 1 00:28:55.343: TCP src=3D2996, dst=3D6881, seq=3D1131934866, ack=3D0, win=3D64240 SYN
*Mar 1 00:28:55.347: IP: s=3D196.202.254.160 (Dialer1), d=3D217.164.181.8, len 48, rcvd 1
*Mar 1 00:28:55.347: tcp0: I LISTEN 196.202.254.160:2996
217.164.181.8:6881 seq 1131934866 OPTS 8 SYN WIN 64240
*Mar 1 00:28:55.347: TCP: connection attempt to port 6881
*Mar 1 00:28:55.347: TCP: sending RST, seq 0, ack 1131934867
*Mar 1 00:28:55.347: TCP: sent RST to 196.202.254.160:2996 from
217.164.181.8:6881
*Mar 1 00:28:55.351: IP ARP: sent req src 217.164.181.8
0012.807b.3967, dst 196.202.254.160 0000.0000.0000 Dialer1
*Mar 1 00:28:55.351: Di1 DDR: bridge (0x0806), 42 bytes, outgoing interesting (pppox over dialer)
*Mar 1 00:28:55.351: DDR: FFFFFFFF FFFF0012 807B3967 08060001 08000604
00010012
*Mar 1 00:28:55.355: DDR: 807B3967 D9A4B508 00000000 0000C4CA FEA0
*Mar 1 00:28:55.359: Di1 DDR: dialer_fsm_up()
*Mar 1 00:28:55.359: Vi2 PPP: Outbound bridge packet dropped, BCP is Closed [starting negotiations]
*Mar 1 00:28:55.359: Vi2 BCP: State is Listen
Could anyone tell me what is wrong.???
Urgent=20
Thanks and Regards
