Cisco 7204VXR Interface ignored packet
Threaded View
Hallo,
i have a problem with ignore packets in the interface.
Hier are the data:
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(5a), RELEASE
SOFTWARE (fc1)
isco 7204VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes
of memory.
Processor board ID 20398977
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points. This
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on CCO <www.cisco.com>, for c7200
bandwidth points oversubscription/usageguidelines.
4 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
GigabitEthernet1/0 is up, line protocol is up
  Hardware is WISEMAN, address is 0002.fc72.7c1c (bia 0002.fc72.7c1c)
  Internet address is xxx.xxx.xxx.xxx
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 14/255, rxload 21/255
  Encapsulation ARPA, loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is
unknown 19
  output flow-control is unsupported, input flow-control is unsupported
  ARP type: ARPA, ARP Timeout 04:00:00
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:15:45
  Input queue: 0/75/8/125 (size/max/drops/flushes); Total output drops: 2800
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 82370000 bits/sec, 10382 packets/sec
  30 second output rate 56693000 bits/sec, 23152 packets/sec
     9603201 packets input, 1095482656 bytes, 0 no buffer
     Received 1241 broadcasts, 0 runts, 0 giants, 2 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 1877 ignored
     0 watchdog, 0 multicast, 0 pause input
     0 input packets with dribble condition detected
     20572688 packets output, 2218072504 bytes, 0 underruns
     0 output errors, 0 collisions, 0 interface resets
     0 babbles, 0 late collision, 0 deferred
     0 lost carrier, 0 no carrier, 0 pause output
     0 output buffer failures, 0 output buffers swapped out
Interface GigabitEthernet1/0(idb 0x633FE930)
Hardware is WISEMAN 2.1, network connection mode is auto
  network link is up
  loopback type is none
  startup time: 38419 usec
  GBIC type is unknown 13
  idb->lc_ip_turbo_fs=0x606224E8, ip_routecache=0x11(dfs=0/mdfs=0),
max_mtu24
  fx1000_ds(tx)=0x2009131C(0x2009131C),
registers(tx)=0x3C800000(0x3C800000), curr_intr=0
  rx cache size 00, rx cache end72, rx_nobuffer=0
 FX1000 registers:
  CTRL  =0x00180005, STATUS=0x0000000F
  FCAL  =0x00C28001, FCAH  =0x00000100, FCT   =0x00008808, FCTTV =0x000016E3
  RCTL  =0x00428022, RDBAL0=0x2C351000, RDBAH0=0x00000000, RDLEN0=0x00000800
  RDH0  =0x00000073, RDT0  =0x00000072, RDTR0 =0x00000000, IMS   =0x000002D6
  TCTL  =0x000400FA, TIPG  =0x00A0080A, TQC   =0x00000000, TDBAL =0x2C352000
  TDBAH =0x00000000, TDLEN =0x00001000, TDH   =0x0000006A, TDT   =0x0000006A
  TXCW  =0xC00001A0, RXCW  =0xDC004020, FCRTL =0x80001200, FCRTH =0x0000AFF0
  RDFH  =0x0000000F, RDFT  =0x0000000F, TDFH  =0x00000426, TDFT  =0x00000426
  RX=normal, enabled  TX=normal, enabled
  Device status=full-duplex, link up, tx clock, rx clock
  AN status=done(RF:0 , PAUSE:0 ), SYNC'ed, rx idle stream, rx invalid
symbols, rx idle char
 GBIC registers:
  Register 0x00:   01  00  00  00  00  00  08  00
  Register 0x08:   00  00  00  01  00  00  00  00
  Register 0x10:   00  00  64  00  43  49  53  43
  Register 0x18:   4F  40  53  59  53  54  45  4D
  Register 0x20:   53  20  20  20  00  20  20  20
  Register 0x28:   57  53  2D  47  35  34  38  33
  Register 0x30:   20  20  20  20  20  20  20  20
  Register 0x38:   20  20  20  20  00  00  00  89
  Register 0x40:   00  12  00  00  46  48  48  31
  Register 0x48:   31  35  35  35  38  30  34  20
  Register 0x50:   20  20  20  20  30  30  31  32
  Register 0x58:   31  35  20  20  00  00  00  8E
  PartNumber: WS-G5483
  PartRev: S
  SerialNo: FHH11555804
  Options:  0
  Length(9um/50um/62.5um): 000/000/000
  Date Code: 001215
  Gigabit Ethernet Codes:  8
 PCI configuration registers:
  bus_no=5, device_no=0
  DeviceID=0x1000, VendorID=0x8086, Command=0x0116, Status=0x0200
  Class=0x02/0x00/0x00, Revision=0x03, LatencyTimer=0xFC, CacheLineSize=0x10
  BaseAddr0=0x48800004, BaseAddr1=0x00000000, MaxLat=0x00, MinGnt=0xFF
  SubsysDeviceID=0x1000, SubsysVendorID=0x8086
  Cap_Ptr=0x00000000  Retry/TRDY Timeout=0x00000000
  PMC=0x00210001  PMCSR=0x00000000
 FX1000(type=0x98) Internal Statistics:
  rxring(128)=0xC351000, shadow=0x633FFCA4, head5, rx_buf_sizeQ2
  txring(256)=0xC352000, shadow=0x20091688, head4, tail4
  tx_int_txdw=0, tx_int_txqe=0, rx_int_rxdmt0=0, rx_int_rxt0=0
  tx_count=0, txring_full=0, rx_max=0, filtered_pak=0
  rx_overrun=0, rx_seq=0, reg_read=0, reg_write=0
  rx_count8, throttledˆ8, enabledˆ8, disabledˆ8
  rx_no_enp=0, rx_discard=0, link_reset=0, pci_rev=3
  tbl_overflow=0, chip_state=2, tx_nonint_done=0, tx_limited=0
  reset=4(init=0, check=0, restart=3, pci=0), auto_restart=4
  tx_carrier_loss=4, fatal_tx_err=0, tx_stucks_count=0
  isl_err=0, wait_for_last_tdt=0, ctrl800005, ctrl0900005
  rx_stucks_count=0, rdtr_fpd25
 HW addr filter: 0x5004BA80, ISL disabled, Promiscuous mode disabled
  Entry= 0:  Addr
Site Timeline
