I am hoping someone can help me with this problem. Currently, I have an enterprise router, a Cisco 3600 that has four serial ports configured for T1 wan connections and Ethernet0/0 as the local LAN ethernet port (192.168.3.1) I am switching over from the T1 connections to fiber for the three of the four outside facilities. The fiber company pulled fiber and told me that they are now all configured in a VLAN. I have one ethernet cable that they are telling me that I just need to plug into the router. That's my problem. I don't know where to start. At first, I thought I could assign Ethernet0/1
192.168.3.2, plug the fiber into that and then add routing statements to tell it to get to 192.168.4.0, 5.0, and 6.0 to send the packet to 192.168.3.2. It wouldn't let me assign that IP to ethernet0/1. Strike 1. I then assigned 192.168.100.1 to ethernet0/1 and then added ip route 192.168.4.0 255.255.255.0 192.168.100.1, but it told me I couldn't add the route because the 100.1 interface is the same router. I also couldn't even ping 192.168.100.1 while telnetted to the router. Strike 2. Am I even thinking about this correctly? I am assuming I need to address Ethernet0/1, give it an IP address, plug in the ehternet cable to the fiber vlan, and then add routing statements to network id's in the VLAN so they go over Ethernet0/1 and not Ethernet0/0.I hope my explanation isn't too confusing.
