Thanks for the quick response, James. In answer to your response about the default of the interfaces being shutdown on a new config, I did do a "no shut" command on the interfaces to make sure they were active.
The one difference in hardware that I see is that the production router's serial interface is DSCC4 and the backup router's serial interface is QUICC as show below - not sure what this is. I've included the Serial and one sub-interface from each router in addition to the diag and ver for each. The are shown in that order beginning with the production server first.
Detroit is the production router shown below:
detroit#sh int Serial0/0 is up, line protocol is up Hardware is DSCC4 with integrated T1 CSU/DSU MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, reliability 255/255, txload 69/255, rxload 19/255 Encapsulation FRAME-RELAY, loopback not set Keepalive set (10 sec) LMI enq sent 302224, LMI stat recvd 302223, LMI upd recvd 0, DTE LMI up LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0 LMI DLCI 1023 LMI type is CISCO frame relay DTE Broadcast queue 0/64, broadcasts sent/dropped 8289374/0, interface broadcasts
7181731 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 5w0d Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 41000 bits/sec, 30 packets/sec 5 minute output rate 138000 bits/sec, 30 packets/sec 52068899 packets input, 2263869777 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 3 giants, 0 throttles 3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 51592125 packets output, 2337495093 bytes, 0 underruns 0 output errors, 0 collisions, 113 interface resets 0 output buffer failures, 0 output buffers swapped out 7 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/0.7 is up, line protocol is up Hardware is DSCC4 with integrated T1 CSU/DSU Description: Circuit to Mansfield AREC0045246 Internet address is 10.100.33.1/24 MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, reliability 255/255, txload 67/255, rxload 22/255 Encapsulation FRAME-RELAY
detroit#sh diag Slot 0: NM-1FE2W Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware Revision : 1.0 Part Number : 800-04796-01 Board Revision : G0 Deviation Number : 0-0 Fab Version : 05 PCB Serial Number : JAD05450AZE RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 D7 41 01 00 C0 46 03 20 00 12 BC 01 0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30 0x20: 35 34 35 30 41 5A 45 03 00 81 00 00 00 00 04 00 0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0: FT1 Hardware revision 1.3 Board revision B0 Serial number 13858613 Part number 800-03279-03 Test history 0x0 RMA number 00-00-00 Connector type Wan Module EEPROM format version 2 EEPROM contents (hex): 0x20: 02 11 01 03 00 D3 77 35 50 0C CF 03 00 00 00 00 0x30: 58 00 00 00 99 04 21 01 FF FF FF FF FF FF FF FF
Slot 1: CT1 (CSU) Port adapter, 1 port Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.1 Board revision B0 Serial number 12422735 Part number 800-01228-04 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 26 01 01 00 BD 8E 4F 50 04 CC 04 00 00 00 00 0x30: 58 00 00 00 99 02 02 00 FF FF FF FF FF FF FF FF
detroit#sh ver Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3640-I-M), Version 12.1(1)T, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2000 by cisco Systems, Inc. Compiled Sat 18-Mar-00 04:31 by ccai Image text-base: 0x600088F0, data-base: 0x608E4000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE (f c1)
detroit uptime is 5 weeks, 8 minutes System returned to ROM by power-on System image file is "flash:c3640-i-mz.121-1.T.bin"
cisco 3640 (R4700) processor (revision 0x00) with 27648K/5120K bytes of memory. Processor board ID 12906564 R4700 CPU at 100Mhz, Implementation 33, Rev 1.0 Bridging software. X.25 software, Version 3.0.0. Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
22 Serial network interface(s)
1 Channelized T1/PRI port(s) DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
************************************************************************************* Detroit_Backup is the backup router shown below:
Detroit_Backup#sh int Serial0/0 is down, line protocol is down Hardware is QUICC with integrated T1 CSU/DSU MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, rely 255/255, load 1/255 Encapsulation FRAME-RELAY, loopback not set, keepalive set (10 sec) LMI enq sent 0, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0 LMI DLCI 1023 LMI type is CISCO frame relay DTE Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0 Last input never, output never, output hang never Last clearing of "show interface" counters never Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 5042 packets output, 389412 bytes, 0 underruns 0 output errors, 0 collisions, 17 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=down DSR=up DTR=up RTS=up CTS=down
Serial0/0.7 is down, line protocol is down Hardware is QUICC with integrated T1 CSU/DSU Description: Circuit to Mansfield AREC0045246 Internet address is 10.100.33.1/24 MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, rely 255/255, load 1/255 Encapsulation FRAMEter is 0x2102
Detroit_Backup#sh diag Slot 0: Combo 1E, 2W port adapter, 3 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.2 Board revision C0 Serial number 16212442 Part number 800-01789-05 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 37 01 02 00 F7 61 DA 50 06 FD 05 00 00 00 00 0x30: 60 00 00 00 99 10 21 17 FF FF FF FF FF FF FF FF
WIC Slot 1: FT1 Hardware revision 1.3 Board revision C0 Serial number 16213537 Part number 800-03279-03 Test history 0x0 RMA number 00-00-00 Connector type Wan Module EEPROM format version 2 EEPROM contents (hex): 0x20: 02 11 01 03 00 F7 66 21 50 0C CF 03 00 00 00 00 0x30: 60 00 00 00 99 10 22 01 FF FF FF FF FF FF FF FF
Slot 1: Combo 1E, 2W port adapter, 3 ports Port adapter is analyzed Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.2 Board revision C0 Serial number 16212455 Part number 800-01789-05 Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x20: 01 37 01 02 00 F7 61 E7 50 06 FD 05 00 00 00 00 0x30: 60 00 00 00 99 10 21 17 FF FF FF FF FF FF FF FF
Detroit_Backup#sh ver Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-I-M), Version 12.0(5), RELEASE SOFTWARE (fc1) Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Wed 16-Jun-99 15:13 by phanguye Image text-base: 0x60008918, data-base: 0x60652000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f c1)
Detroit_Backup uptime is 1 hour, 14 minutes System restarted by power-on System image file is "flash:c3620-i-mz.120-5"
cisco 3620 (R4700) processor (revision 0x81) with 24576K/8192K bytes of memory. Processor board ID 15826831 R4700 processor, Implementation 33, Revision 1.0 Bridging software. X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s) DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup# Detroit_Backup#
