Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by squid on June 15, 2008, 4:56 am
Please log in for more thread options I have a cisco 3640 router am trying to add a fastethernet card but the IOS is not detecting it.The card has been tested and working on other routers. I upgraded from IOS c3640-d-mz.112-7a.P to c3640-js-mz. 122-40 but still is unable to detect it. The port has a serial interface that is ok please help. Squid | ||||||||||||||||||||||
Posted by Andre Wisniewski on June 15, 2008, 10:01 am
Please log in for more thread options http://www.cisco.com/en/US/products/hw/routers/ps274/products_relevant_interfaces_and_modules.html Check whether you can find your module in these list. If so click on the module's name and check needs to run the module. For NM-1GE for example you can find this: Product Number Minimum Cisco IOS Software Version NM-1GE 12.2(11)YT Supported Platforms Maximum Number of Modules Supported Cisco 2691 1 Cisco 3660 2 Cisco 3725 1 Cisco 3745 2 Cisco 3825 1 Cisco 3845 2 As you can see this one isn't supported on C3640. Maybe that's the case for your module. Can't tell you exactly, you didn't give us the exact module's name. I know this one isn't your module :) | ||||||||||||||||||||||
Posted by squid on June 15, 2008, 3:23 pm
Please log in for more thread options > squid wrote:
> > Hellos,
> > I have a cisco 3640 router am trying to add a fastethernet card but > > the IOS is not detecting it.The card has been tested and working on > > other routers. I upgraded from IOS c3640-d-mz.112-7a.P to c3640-js-mz. > > 122-40 but still is unable to detect it. The port has a serial > > interface that is ok please help. >
> > Squid
your
> http://www.cisco.com/en/US/products/hw/routers/ps274/products_relevan... > > Check whether you can find your module in these list. If so click on the > module's name and check needs to run the module. > > For NM-1GE for example you can find this: > > Product Number Minimum Cisco IOS Software Version > NM-1GE 12.2(11)YT > > Supported Platforms Maximum Number of Modules Supported > Cisco 2691 1 > Cisco 3660 2 > Cisco 3725 1 > Cisco 3745 2 > Cisco 3825 1 > Cisco 3845 2 > > As you can see this one isn't supported on C3640. Maybe that's the case for > module. Can't tell you exactly, you didn't give us the exact module's name.
> > I know this one isn't your module :) WIC 1ENET is the module am using Thanks squid | ||||||||||||||||||||||
Posted by Doug McIntyre on June 15, 2008, 10:32 am
Please log in for more thread options >I have a cisco 3640 router am trying to add a fastethernet card but
>the IOS is not detecting it.The card has been tested and working on >other routers. I upgraded from IOS c3640-d-mz.112-7a.P to c3640-js-mz. >122-40 but still is unable to detect it. The port has a serial >interface that is ok please help. Which FastEthernet card are you trying to add? NM-1FE2W are used all the time the 3640's. NM-1FE-TXs should work just peachy too with just about any rev software. If its one of these, what does a 'show diag' have? Most likely its a supported one and not showing up. | ||||||||||||||||||||||
Posted by squid on June 15, 2008, 3:27 pm
Please log in for more thread options > >I have a cisco 3640 router am trying to add a fastethernet card but
> >the IOS is not detecting it.The card has been tested and working on > >other routers. I upgraded from IOS c3640-d-mz.112-7a.P to c3640-js-mz. > >122-40 but still is unable to detect it. The port has a serial > >interface that is ok please help. >
> Which FastEthernet card are you trying to add? > > NM-1FE2W are used all the time the 3640's. > NM-1FE-TXs should work just peachy too with just about any rev software. > > If its one of these, what does a 'show diag' have? > > Most likely its a supported one and not showing up. Hello Doug, WIC 1ENET is the module am using Thanks squid | ||||||||||||||||||||||
cisco 3600 fastethernet
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Squid
