Can anyone tell me if the Cisco 350 Access Point will support a dual SSID, with one being WEP encrypted and the other on being WPA?
This would help me with the transition from WEP to WPA. My plan is to start the 350s broadcasting WPA as well as WEP, then change the devices over one at a time, when its convenient.
I also have 1200 and 1242 access points. I'm assuming that they /will/ do what I need.
The firmware on the 350s is 12.2(15)XR2
Thanks, SW
