Switch is a Cisco 2960-24TC IOS 150-1.SE1
First let me say this switch is suppose to do layer 3 routing, which I've enabled with:
Switch(config)#sdm prefer lanbase-routing
I have two vlans setup vlan1 and vlan2 and I want to be able to route between them, I can ping from vlan2 to vlan1 and the other way, but can't ping any of the computers hooked to the ports between vlans.
Here I'm pinging from vlan2 to vlan1 and it works
Switch#ping Protocol [ip]: Target IP address: 192.168.100.1 Repeat count [5]: Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: y Source address or interface: vlan2 Type of service [0]: Set DF bit in IP header? [no]: Validate reply data? [no]: Data pattern [0xABCD]: Loose, Strict, Record, Timestamp, Verbose[none]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.100.1, timeout is 2 seconds: Packet sent with a source address of 10.5.60.14 !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Now if I try to ping 192.168.100.2 which is a PC on a vlan1 ethernet port, it doesn't work.
Switch#ping Protocol [ip]: Target IP address: 192.168.100.2 Repeat count [5]: Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: y Source address or interface: vlan2 Type of service [0]: Set DF bit in IP header? [no]: Validate reply data? [no]: Data pattern [0xABCD]: Loose, Strict, Record, Timestamp, Verbose[none]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.100.2, timeout is 2 seconds: Packet sent with a source address of 10.5.60.14 ..... Success rate is 0 percent (0/5)
Here is the config
! aaa session-id common system mtu routing 1500 ip routing ! ! mls qos ! ! spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! ! interface FastEthernet0/1 switchport access vlan 2 ! interface FastEthernet0/2 switchport access vlan 2 ! interface FastEthernet0/3 ! interface FastEthernet0/4 ! interface FastEthernet0/5 ! interface FastEthernet0/6 ! interface FastEthernet0/7 ! interface FastEthernet0/8 ! interface FastEthernet0/9 ! interface FastEthernet0/10 ! interface FastEthernet0/11 ! interface FastEthernet0/12 ! interface FastEthernet0/13 ! interface FastEthernet0/14 ! interface FastEthernet0/15 ! interface FastEthernet0/16 ! interface FastEthernet0/17 ! interface FastEthernet0/18 ! interface FastEthernet0/19 ! interface FastEthernet0/20 ! interface FastEthernet0/21 ! interface FastEthernet0/22 ! interface FastEthernet0/23 ! interface FastEthernet0/24 ! interface GigabitEthernet0/1 ! interface GigabitEthernet0/2 ! interface Vlan1 ip address 192.168.100.1 255.255.255.0 ! interface Vlan2 ip address 10.5.60.14 255.255.255.192 ! ! ip http server ip http secure-server logging esm config ! !
