Hi:
I have recently purchased a new Cisco 2821 with 2 WIC-1dsu-t1-v2 cards. I have 2 bonded T1 lines that I need to connect this to. What is the best way for me to get the greatest use out of. Any links , etc would be helpful.
Hi:
What do you mean by 2 bonded T1 lines" ?
Do you mean anexternal multiplexer ?
Do you mean IP load balancing ?
What is at the other end of the two T1's ?
So if this is T1 loop bonding, then I would expect the provider to have to provide you with a IMUX unit.
Has the service been installed and if so what did the carrier install (make & model)?
