Hello I have a problem:
I have one C2651XM 48F/256D with one WIC-ADSL on a 7M/512k ADSL LINE
Just a simple ACL inbound, NAT1-1 towards client and nothing else. I get at 3mbit throughput download, about 25% CPU usage.
It seem very high to me, since I plan to put later a second WIC ADSL to use a second adsl line.
(actually in the router there are 4 wic adsl, but two will be removed , and the NM-2W with them).
IOS is 12.4(25)b IPBASEK9
This is my current conf:
gw1.wisp#sh run Building configuration...
Current configuration : 7834 bytes ! version 12.4 service nagle no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service internal service sequence-numbers ! hostname gw1.wisp ! boot-start-marker boot-end-marker ! logging buffered 65535 notifications no logging console no logging monitor enable password 7 xxxxxxxxxxxxxx! no aaa new-model clock timezone CET 1 no network-clock-participate slot 1 no network-clock-participate wic 0 no ip source-route no ip gratuitous-arps ip cef ! ! ! ! no ip bootp server ip domain round-robin ip domain name spadhausen.com ip name-server 212.97.32.2 ip name-server 94.141.24.92 login block-for 120 attempts 5 within 60 login on-failure log ! ! ! username zzz privilege 15 password 7 xxxxx archive log config hidekeys ! ! ip tcp ecn ip tcp selective-ack ip tcp timestamp ip tcp window-size 65535 ip tcp synwait-time 10 ip ssh time-out 90 ip ssh version 2 ! ! interface Null0 no ip unreachables ! interface ATM0/0 description xxx no ip address no ip redirects no ip proxy-arp atm restart timer 300 atm ilmi-keepalive dsl operating-mode auto clock rate aal5 7000000 ! interface ATM0/0.1 point-to-point ip address 89.186.xxxx 255.255.255.252 ip access-group 100 in no ip unreachables no ip proxy-arp ip nat outside pvc 8/35 encapsulation aal5snap ! ! interface FastEthernet0/0 description Interfaccia verso la backbone interna ip address 172.16.0.1 255.255.254.0 no ip redirects no ip proxy-arp ip nat inside duplex auto speed auto ! interface ATM0/1 no ip address shutdown atm restart timer 300 no atm ilmi-keepalive dsl operating-mode auto clock rate aal5 7000000 ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface ATM1/0 no ip address shutdown atm restart timer 300 no atm ilmi-keepalive dsl operating-mode auto ! interface ATM1/1 no ip address shutdown atm restart timer 300 no atm ilmi-keepalive dsl operating-mode auto ! interface Dialer0 no ip address no cdp enable ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 ATM0/0.1 ip route 172.16.2.0 255.255.255.0 172.16.0.254 ip route 172.16.3.0 255.255.255.0 172.16.0.254 ip route 172.16.4.0 255.255.255.0 172.16.0.254 ip route 172.16.5.0 255.255.255.0 172.16.0.254 ip route 172.16.6.0 255.255.255.0 172.16.0.254 ip route 172.16.7.0 255.255.255.0 172.16.0.254 ip dns server ! no ip http server no ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ip nat translation timeout 3600 ip nat translation tcp-timeout 1200 ip nat translation udp-timeout 100 ip nat translation finrst-timeout 15 ip nat translation syn-timeout 45 ip nat translation icmp-timeout 120 ip nat inside source list 101 interface ATM0/0.1 overload here just some nat 1-1 ! ! no logging trap access-list 99 permit 77.93.235.238 access-list 99 permit 172.16.0.0 0.0.1.255 access-list 101 permit ip 172.16.0.0 0.0.1.255 any snmp-server community public RO 99 snmp-server ifindex persist snmp-server location MG Casa snmp-server contact snipped-for-privacy@spadhausen.com no cdp run ! control-plane ! banner login ^C You are connected to $(hostname).$(domain) on line $(line). If you are not authorized to access this system, disconnect now.
THIS IS FOR AUTHORIZED USE ONLY
Unauthorized or improper use of this system may result in administrative disciplinary action and civil and criminal penalties. By continuing to use this system you indicate your awareness of and consent to these terms and conditions of use. LOG OFF IMMEDIATELY if you do not agree to the conditions stated in this warning.
Network Administrator: snipped-for-privacy@spadhausen.com ^C ! line con 0 login local line aux 0 line vty 0 4 privilege level 15 login local transport input ssh ! scheduler max-task-time 5000 ntp clock-period 17208075 ntp server 192.43.244.18 ntp server 193.204.114.105 ! end
