Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Mike Rahl on June 16, 2008, 11:29 am
Please log in for more thread options I recently won a cisco 2611-dc router off ebay, without reading that it was, in fact, a DC router until too late. I am now attempting to find the appropriate cable to use to power the router Can anyone tell me where I can get the power cable for a Cisco 2611-dc router, and what the part number is? Thanks! | ||||||||||||||||
Posted by Doug McIntyre on June 16, 2008, 1:38 pm
Please log in for more thread options >I am now attempting to find the appropriate cable to use to power the
>router >Can anyone tell me where I can get the power cable for a Cisco 2611-dc
>router, and what the part number is? Typically, a DC powered router has power brought to it, it doesn't "plug in" or need a cable for it. The typical wire used to bring power to it is stock THHN sold everywhere, you can buy it by the foot at Home Depot/Lowes. Just get something like 14AWG or 12AWG THHN. Stranded is alot easier to work with rather than solid. You just route the wires down from your DC fuse panel at the top of your rack fed from your DC plant.. But, my guess is that you need DC power at -48V in the first place? There's going to be plenty of rectifiers available on eBay, DC power isn't that unusual for many activities outside of networking.. This one looks fairly cheap and sources enough juice.. (be careful of the terminals, it looks like the AC ones are bare? probably meant to be stuffed into a NEMA box of somekind) http://cgi.ebay.com/Meanwell-DRP-240-48-48V-5A-DC-Switching-Power-Supply_W0QQitemZ320262520432QQihZ011QQcategoryZ58288QQssPageNameZWDVWQQrdZ1QQcmdZViewItem The 2611-DC seems to take 2A per the data sheet. Just connect the + output to the common input on the router, and the - output to the -48V input on the router). Or something like http://cgi.ebay.com/Tellabs-48V-2A-DC-Power-Supply-8021_W0QQitemZ180234242261QQihZ008QQcategoryZ36323QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 is from a telco vendor which is the large consumer of -48V DC power.. Probably for a small item that would be out in the field away from the DC plant in the first place.. But it also just covers the input needs of the router. Probably be fine, I'm sure the router doesn't draw its max current anyway. I'd probably go for the Tellabs one myself. Get a couple foot length chunks of THHN (red and black) and connect it up with the right polarity (checking with your VOM) to have -48V go to the input side of the router. | ||||||||||||||||
Posted by Merv on June 16, 2008, 2:41 pm
or put your "prize" up for sale on ebay ... | ||||||||||||||||
Posted by Mike Rahl on June 16, 2008, 3:37 pm
Please log in for more thread options > or put your "prize" up for sale on ebay ...
Thanks for the advice all Does anyone know if it is possible to swap out the DC power supply for an AC power supply? I don't think the AC power supplies are expensive (they'd probably cost me the same as buying all the paraphernelia for running DC power) Thanks! | ||||||||||||||||
Posted by on June 16, 2008, 11:14 pm
> Thanks for the advice all > > Does anyone know if it is possible to swap out the DC power supply for > an AC power supply? =A0I don't think the AC power supplies are expensive > (they'd probably cost me the same as buying all the paraphernelia for > running DC power) > > Thanks! List for AC supply seems to be about $80. This one $15. PWR-2600-AC > Cisco > RoutersPhoto of PWR-2600-AC -
Click to zoom in =B7 Enlarge Photo. PWR-2600-AC ...
Our Price: $15.00 Stock Status: 49 Refurbished units in stock. ... horizondatacom.com/eCart/browse/productinfo.php?manpartnum=3DPWR-2600- AC&flash=3D0&dram=3D0&price=3D1... - 26k - Cached - Similar pages It would be very surprising if it was not a screwdriver swap (and of course dealing with any push on connectors) -- however I don't know. I am not certain that the above is the correct PSU for you either. Sorry. | ||||||||||||||||
| Similar Threads | Posted |
| cisco 2611-dc power cable | June 16, 2008, 11:29 am |
| Cisco Power over Ethernet PoE | November 15, 2005, 11:05 am |
| cisco pix 506 power supply pin out | July 6, 2005, 11:02 am |
| Cisco 1601 Power Supplies | June 2, 2006, 4:19 pm |
| Cisco Aironet 350 A/P power question | October 17, 2006, 1:30 am |
| max power usage for cisco 4506 loaded | July 26, 2007, 4:53 pm |
| power over ethernet, cisco 2600 router | November 23, 2008, 3:02 pm |
| PB with cisco cable | January 24, 2006, 8:23 am |
| Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 6:40 am |
| Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 7:32 am |
| Cisco Pix 501 Problem with Cox Cable | October 4, 2005, 2:11 pm |
| Cisco Routers & Cable Modems | May 30, 2006, 2:25 pm |
| Cable TV boxes with the Cisco brand | November 18, 2005, 1:09 pm |
| Cisco Soho 91 and cable modem | April 24, 2007, 12:54 am |
| Cisco 1801 for use on cable internet? | June 20, 2007, 5:34 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
