I installed the NM and the VIC but do not get anything when I try and conifgure the voice ports.
oip-rtr(config)#voice-port ^ % Invalid input detected at '^' marker.
voip-rtr(config)#
Here is my IOS and sh run and ver -- no voice ports showing up:
isco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(3i), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Fri 12-Aug-05 13:36 by ssearch Image text-base: 0x80008098, data-base: 0x819EA9AC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
voip-rtr uptime is 30 minutes System returned to ROM by power-on System image file is "flash:c2600-is-mz.123-3i.bin"
cisco 2610XM (MPC860P) processor (revision 0x300) with 94208K/4096K bytes of mem ory. Processor board ID JAE08127Q3B (406705196) M860 processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s) 2 Serial network interface(s) 2 Voice FXO interface(s) 32K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write)voip-rtr#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
voip-rtr#
Current configuration : 713 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname voip-rtr ! boot-start-marker boot system flash c2600-is-mz.123-3i.bin boot-end-marker ! logging buffered 4096 debugging ! no aaa new-model ip subnet-zero ip cef ! ! no ip domain lookup
! ! ! ! ! ! ! ! ! ! no voice hpi capture buffer no voice hpi capture destination ! ! ! ! ! ! interface FastEthernet0/0 ip address dhcp duplex auto speed auto ! ! interface Serial0/0 no ip address shutdown no fair-queue ! interface Serial0/1 no ip address shutdown ! ip http server ip classless ! ! ! ! ! ! ! ! ! line con 0 line aux 0 line vty 0 4
How do I get these ports to be identified?
THANKS for any help
