Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on February 18, 2006, 7:50 pm
i got a problem after i config the 2610 and then 'wr mem' or even i try 'copy run start' to save teh config. but everything is reset when i reload it. hardware problem? memory problem? IOS problem? pls advice, thanks. paul | |||||||||||||
Posted by Doan on February 18, 2006, 8:04 pm
Please log in for more thread options Check the config register. Doan On 18 Feb 2006 b.mwlam@gmail.com wrote: | |||||||||||||
Posted by on February 18, 2006, 9:57 pm
Please log in for more thread options hi
thanks for your reply. you are right. the config-reg is 0x2142. and it should be 0x2102 , right? thanks paul Doan =E5=AF=AB=E9=81=93=EF=BC=9A > Check the config register.
> > Doan > > On 18 Feb 2006 b.mwlam@gmail.com wrote: > > > hi all,
> > > > i got a problem after i config the 2610 and then 'wr mem' or even i try > > 'copy run start' to save teh config. but everything is reset when i > > reload it. hardware problem? memory problem? IOS problem? > > > > pls advice, thanks. > > > > paul > > > > | |||||||||||||
Posted by ciscodagama@gmail.com on February 19, 2006, 2:32 pm
Please log in for more thread options Yes, the 0x40 is causing the startup configuration in NVRAM to be
ignored. Setting the configuration register to 0x2102 should solve your problem. Please look at http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2505/2500him/77108.htm for details about the bits in the configuration register. Cisco da Gama http://ciscostudy.blogspot.com | |||||||||||||
| Similar Threads | Posted |
| cisco 2610 config problem | February 18, 2006, 7:50 pm |
| quick config for 2610 t-1 router to netgear firewall? | February 6, 2009, 4:28 pm |
| Problem: 2610 with XM image | January 28, 2006, 4:04 pm |
| 2610 Nat or problem with browsing web | October 8, 2006, 11:00 am |
| arrow key problem with 2610 | March 9, 2007, 3:22 pm |
| cisco pix 515 config problem (ver 7.3) | July 19, 2007, 8:51 am |
| Problem config Cisco 877w | October 26, 2005, 5:02 am |
| Cisco PIX Client VPN Config Problem | August 8, 2007, 3:49 pm |
| CISCO 2950 vlan config problem | August 18, 2005, 9:01 am |
| Cisco 2610 BGP | November 17, 2005, 11:49 pm |
| Cisco 2610 Defaults | May 19, 2006, 8:48 am |
| Cisco 2610 Router | September 14, 2006, 11:28 am |
| CIsco 2610 Trunking question | August 22, 2006, 6:15 pm |
| HELP! Cisco 2610 stuck in boot loop! | August 28, 2006, 10:14 am |
| Interconnecting two pbx over CEoIP on Cisco 2610 and 2811 | December 15, 2006, 10:29 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> pls advice, thanks.
> paul
