Hello,
I'm trying to implement a Cisco 1841 with 2 modules, 1 SDSL + 1 ISDN. The SDSL interface is the primary inteface. The ISDN interface is meant as a backup interface in case the ISDN interface fails.
The problem is that the SDSL interfaces rarely goes doen. If there is a problem with the ISP, the link rarely goes doen, and the ISDN doesn't take over. Therefor, the backup interface command is no use.
The second problem i am having, when i pull out the DSL cable, is that i'm using Dialer interfaces. Because Dialer interfaces a virtual, they never go down. As a result of that, i'm having problems with my static routes. Both static routes are up, and traffic is also sent over the interface that is down.
Now i lookup at discussion groups, and some tips i saw were:
PBR:
The link should be:
Here below is my config. This is a standard config, with no backup settings here. Can someone take a look, en possibly help me with this?:
! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname router ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings enable secret ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ! username password ! ! controller DSL 0/0/0 mode atm line-term cpe line-mode 2-wire line-zero dsl-mode shdsl symmetric annex B line-rate auto ! interface FastEthernet0/0 description LAN klant ip address duplex auto speed auto no keepalive ! interface BRI0/1/0 description Inbel interface no ip address encapsulation ppp no ip route-cache no ip mroute-cache dialer pool-member 2 no fair-queue no shutdown ! interface ATM0/0/0 no shutdown no ip address no atm ilmi-keepalive pvc 0 0/36 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface Dialer 0 mtu 1492 ip unnumbered FastEthernet0/0 encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer-group 1 no cdp enable ppp authentication pap callin ppp pap sent-username password ! interface Dialer1 ip unnumbered FastEthernet0/0 encapsulation ppp dialer remote-name dialer idle-timeout 300 dialer wait-for-carrier-time 10 dialer string XXXXXXXXXX dialer pool 2 dialer-group 2 no fair-queque no cdp enable ppp authentication pap callin ppp pap sent-username password ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ! dialer-list 1 protocol ip permit ! no ip http server ip http authentication local ip http timeout-policy idle 5 life 86400 requests 10000 ! dialer-list 1 protocol ip permit ! control-plane ! ! line con 0 login local line aux 0 line vty 0 4 privilege level 15 login local transport input telnet line vty 5 15 privilege level 15 login local transport input telnet ! end
