Hello,
I have a Cisco 1811 IOS 12.4(6)T11. It has two L3 ports and eight L2 ports. Is it possible to use the L2 ports for separate networks? For example, int f0 is 10.1.4.22 int f1 is 10.10.2.1
Is it possible to assign IP's (networks) to the other interfaces...example:
int f2 10.10.3.1 int f3 10.10.4.1 int f4 10.10.5.1
I'm hoping this can somehow be done via VLAN's. If you can please recommend an example that I can look at or if it's even possible please let me know.
Thanks in advance:)
BTW This is my current config...but secondary IP's will not work with my application: ======================================================== Using 2349 out of 196600 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname lab_ospf ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! no aaa new-model ! resource policy ! ip cef no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool sdm-pool import all network 10.10.10.0 255.255.255.248 default-router 10.10.10.1 lease 0 2 ! no ip domain lookup ip domain name yourdomain.com ! crypto pki trustpoint TP-self-signed-2176816363 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2176816363 revocation-check none rsakeypair TP-self-signed-2176816363 ! crypto pki certificate chain TP-self-signed-2176816363 certificate self-signed 01 nvram:IOS-Self-Sig#3301.cer username cisco privilege 15 secret 5 $1$4NMd$SQ.k0cQsa5kaqCt3bNXOO0 username it privilege 15 secret 5 $1$9q36$O.XeN1qwbCJE9zvkm1v5w. ! interface FastEthernet0 ip address 10.1.4.22 255.255.255.0 duplex auto speed auto ! interface FastEthernet1 ip address 10.10.3.1 255.255.255.0 secondary ip address 10.10.4.1 255.255.255.0 secondary ip address 10.10.2.1 255.255.255.0 duplex auto speed auto ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface FastEthernet5 ! interface FastEthernet6 ! interface FastEthernet7 ! interface FastEthernet8 ! interface FastEthernet9 ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$ no ip address ip tcp adjust-mss 1452 ! interface Async1 no ip address encapsulation slip ! router ospf 100 log-adjacency-changes network 10.10.2.0 0.0.0.255 area 0 network 10.10.3.0 0.0.0.255 area 0 network 10.10.4.0 0.0.0.255 area 0 ! ip route 172.20.1.0 255.255.255.0 10.1.4.1 ! ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! no cdp run ! control-plane ! line con 0 login local line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 access-class 23 in privilege level 15 login local transport input telnet ssh line vty 5 15 access-class 23 in privilege level 15 login local transport input telnet ssh ! ! webvpn context Default_context ssl authenticate verify all ! no inservice end
